Old 11-28-2018, 05:51 AM
dontlifttoshift's Avatar
Thom is using a E92 ECU that came with a GM LT4 connect and cruise. That ECU and harness is set up for two discrete outputs and are already wired to relays in the Chevrolet Performance fuse box.
I also want the answer to this for this application.
Donny
Old 11-28-2018, 05:52 AM
Just so it is all on the same page.
Originally Posted by GodSpeed View Post
I am trying to use a Factory ZL1 camaro fan. I have vintage air as well.
Any one have any success controlling the PWM fan as intended?
Thank you in advance.
Thom
Originally Posted by andrewb70 View Post
Thom,
I have no direct experience with what you are doing, but I have some educated guesses. From what I understand, the ZL1 fans have the controller built into the fan. The connector (Yazaki) has two large pins for power and a small pin for the PWM signal wire. Again, from what I understand, you should be able to configure the ECM to send a PWM- signal to the fan and it should work. I would use the same settings of 128Hz and input the duty cycle table as with the C6 Corvette application.
Andrew
Donny
Old 11-28-2018, 07:47 AM
andrewb70's Avatar
I wish I had one of these fans to experiment with. I'd like to see if they would work with the Holley ECU.
Andrew
Instagram @dr__efi
I offer remote Holley EFI tuning.
I deliver what EFI promises.
Please get in touch if I can be of service.
My YouTube Channel
Old 11-28-2018, 10:30 AM
I don't see why it wouldn't, it wants the same PWM signal.
The crew at V8 Speed said on a FB post that the GMPP E92 for the LT4 is programmable to run a pwm fan signal.
I am waiting for a couple of corroborating experiences, it is costly to undo.
Donny
Old 11-28-2018, 01:43 PM
dhutton dhutton is offline
Andrew
https://www.ebay.com/itm/2012-2015-C...AAAOSwuNFbeH16
Likely won’t find one for any less....
Don
Old 11-30-2018, 08:31 AM
andrewb70's Avatar
Don
Don,
That looks like one of the fans from a 5th gen Camaro. I believe that if we are talking about the e92 ECU, then that would be the 6th gen Camaro...
Andrew
Instagram @dr__efi
My YouTube Channel
Old 11-30-2018, 10:06 AM
Don,
Andrew
Sorry...
Don
Old 11-30-2018, 10:11 AM
andrewb70's Avatar
Sorry...
Don
No need for apologies. I am just trying to keep all of this information as accurate as possible. We're all learning here...LOL
Adapting new OEM parts to our old clunkers is not easy, but I think there are many benefits to be had. As I understand it, the new fans are quite amazing!
Andrew
Instagram @dr__efi
My YouTube Channel
Old 11-30-2018, 10:15 AM
eville's Avatar
eville eville is offline
Andrew
You know we're in deep when we're using words like AMAZING to describe cooling fans... LOL
Steve
'68 Camaro - 355", TKO600, SpeedTech Arms, ATS-AFX Spindles, Hotchkis Springs, Forgeline Wheels, C5 Brakes (Kore3), Holley Terminator EFI
Check it out Here
Old 11-30-2018, 10:21 AM
andrewb70's Avatar
Geeks-R-Us...LOL
In all honesty, PWM fan control adds a great deal of refinement out our old cars. The information from this thread allowed me to implement it on my Cougar build and it truly is AMAZING! On my GTO, I am using dual Spal fans with binary fan control. The car has a relatively quiet exhaust and when the cooling fans turn on, it sounds like a jet engine.
On the Cougar, I never hear the fan, ever, and I have yet to see it go much above 50% duty cycle even on hot summer days. The C6 fan is rated at 400watts, while the new 6th gen Camaro fan, I believe is 800watts! So yes, amazing.
Andrew
Instagram @dr__efi
My YouTube Channel
