Old 05-26-2010, 07:29 AM
Steve1968LS2's Avatar
Originally Posted by ivmotor View Post
Do you still need a gear? I can make another one. I was thinking about selling these things because it is becoming a big problem.
You made a 1X single bolt gear? cool... Do you have a picture?
And yes, i would love to get one.. without it the consensus was that we would just leave it as is and live with it rather than do a cam swap
Greg, it is balanced.. the "bumps" one one side have corresponding "valleys" on the reverse..
Old 05-26-2010, 04:16 PM
ivmotor ivmotor is offline
I didn't take a pic of the last one I did. Here's what I do: mill off the 4x teeth from the gear you have now. Cut a .380" slice off some 4" .375" wall tubing. Weld the slice in the right spot with four rosettes. Bake until a toothpick inserted in the middle comes out dry. Takes me a couple hours...
Old 05-26-2010, 04:45 PM
Its not balanced, its stamped. The valley is the side effect. Other GM gears have the teeth with no valleys.
Old 05-26-2010, 05:33 PM
Why not just mill off the two "extra" nubs -- and weld a piece into the gap of the single bolt version -- thereby making the One signal generator...
Old 05-26-2010, 09:06 PM
It would then have to be balanced.. right now every "bump" has a corresponding "valley" on the reverse...
Old 05-26-2010, 09:07 PM
Really... hmm.. seems odd that it could be that much out of balance and ok...
If the balancing isnt a big deal it could easily be modified
Old 05-26-2010, 09:08 PM
Then I do the frosting??? :yum:
Why not just fill the area between the two large peaks and grind off the two small ones?
Old 05-26-2010, 09:09 PM
Hey, quit reading my mind!!!!!!!!!!!!!!
Old 05-26-2010, 09:16 PM
Sorry.....
Old 05-27-2010, 07:22 AM
The bump would be in the wrong place. Its kind of adding 30 degrees here and grinding 60 degrees off there. I think its easier just to start over.
As far as the balancing goes, we spun a 1x and a 4x gear, they are both off. I don't think the weight of one tooth would make much difference compared to the harmonics of valvetrain.
cake ftw!
