Old 12-26-2006, 06:22 PM
Sales@Dutchboys's Avatar
Looks great! Thanks for the pics.
dutchboyshotrods.com
269-823-2967
Old 12-26-2006, 08:22 PM
Lookin' good Marty, .
1/12th scale 1969 Sunset Orange Metallic Camaro Pro Touring Style>>
Progress Thread
Artwork Page
Old 01-09-2007, 03:39 PM
syborg tt's Avatar
Some say better late then never.
I have a bunch of updates to do so i will post them individually
Dave had to reroute one of the air intake tubes to get around the new inner fender.
We finally made the new lower column mount.
Kevin mounted the Power Steering Tank from Billet Specialties
It was hard but we finally found a location for the a/c drier.
See if you can guess where it's mounted.
marty-mj
Old 01-09-2007, 03:40 PM
syborg tt's Avatar
Dave also mounted the hood pin in the core support.
Ron & I are working on the Skuff plate for the hood.
Pics very soon I promise.
Normally I would say something like more to come next week.
But since I am already 2 weeks behind.
Well someone took the body off my truck.
No actually Dave & Kevin removed it so they could plumb the brake lines.
That's it just thought i would post some pics
marty-mj
Old 01-09-2007, 03:41 PM
syborg tt's Avatar
Just some quick pictures I thought were cool.
Close up of the hood pin
Added a second battery just in case.
still plenty more post to follow
marty-mj
syborg tt's Avatar
Dave ran all the brake lines while the body was off.
This way they could keep everything tight to the frame.
Man I can't wait till the frame is painted.
Brake line running over the rear hoop.
T-Fitting to get the Drivers Side rear Brake.
Quick Shot of the brake line following the frame.
marty-mj
Old 01-09-2007, 03:42 PM
syborg tt's Avatar
This is where the brake line terminates on the frame.
yep there will be more posts
marty-mj
Old 01-09-2007, 03:43 PM
syborg tt's Avatar
While I was in Florida.
I stopped by www.Docskustom.com to have him work on the final dash bezel.
All I can say is what a great guy.
yep still more.
marty-mj
syborg tt's Avatar
Really, I had to take picture of the motor while it was out of the truck.
Dave and I worked on a design for the Turbo Support Brackets.
It will follow the same theme as the Billet Specialties Brackets
Kevin Boxed in the motor mounts.
Yes, there is a drain hole in the back just in case they get wet.
Dave also finished the brake lines in the front.
Side shot.
Harness Bar is welded.
Looks like it's getting really close to coming home to my shop.
marty-mj
Old 01-09-2007, 03:44 PM
syborg tt's Avatar
What more brake line pics.
Just another one of those really expensive t-fittings.
Radiator cover.
Trying to stick with the keep it simple theme.
Your not going to believe it one more post.
marty-mj
