Old 10-25-2016, 11:04 AM
cpd004's Avatar
cpd004 cpd004 is offline
When you leveled the pitman arm, was that done at the flat area where the center link attaches or at the arm itself?
1971 Firebird
2017 SS
Old 10-25-2016, 11:30 AM
gerno's Avatar
gerno gerno is offline
Originally Posted by Dave Pratt View Post
This is so cool to watch guys doing all this great work in their own garage.I'm no welder but I'm looking at getting something for the garage...I'll learn as I go I hope. Great work on the build!!
I'm pretty much doing the same, learning as I go. It certainly gives you a whole different perspective on all aspects of the hobby.
If you are really thinking about a welder I'd look at the new Miller 211 MIG. I sold 1 large and 1 small MIG and replaced them with the 211. Its an awesome machine that's pretty amazing out of the box. Don't think you can beat it for the $$
Originally Posted by preston View Post
I read somewhere that Bruce McLaren himself said designing a race car was primarily a packaging exercise.
Looks like you're on the right path. Of all aspects of (pro tour) car construction, I find the front suspension the most interesting and in fact the dis-satisfaction of trying to band aid the suspension on my '67 Mustang was what got me started building cars in the first place.
Looks like you're doing the right thing and with Ron involved your in the best of hands. And every time you decide not to compromise, you've made the right choice, especially if its mostly an issue of labor (everyone has $ limits).
As much as I like to work on "open design" tube front ends, I find there to be something really satisfying about working with the stock subframe and the original steering gear, for example I found 73CP's thread really interesting for that reason. As long as its someone else's car !
Agreed. I keep checking to see what else I can notice on Brian's car. He used the frame because it was for CP. I used the frame mainly because this is my first huge fab project and honestly I don't think I have the skills to build a complete frame that was correct and straight.... Maybe the next build
It looks great, nice work.
Thank you
Impressive Steve. You are really goin for it (within reason) and stickin with it. I am glad you didn't bail on the Camaro.
Did I hear you picked up some other vehicle in the meantime?
I never planned to give up on the Camaro but I did get another car too. Picked up a 95 Mustang GT with the 5.0 and 5 spd for $1k. It was from the original owner with ~300k miles and the AC still works. Certainly no show car but its a great beater to practice Axing while I get the Camaro back. Last AX I put air in the old tires and added 2 qtr of oil. That was enough to beat out 3 of 5 BMW's on the course. Who knows what will happen with decent tires. Later on I plan to build it up as a NASA CMC car. Wont be as cool as Robs AI car but should be fun none the less.
Weld has seen the beast in person and can attest to how magnificent it is.
Nothing wrong with stepping back every now and then to tend to other priorities...it's all about balance.
Huge kudos for stepping into the deep end with your fab work, I agree...if you are in it this far just keep doing things right instead of compromising. It will pay off in the end.
Agreed. Funny how at first I was annoyed to step away from it but now I'm very glad I did. Although its coming time to get a bit more focus on it if I want to make the March deadline without stressing
I did use that part of the arm. It was the only part flat enough and I am assuming the centerlink hole in it is perpendicular. The Pitman needed to be level because the centerlink joint isn't a ball joint, more of a bushed shaft so I needed a closer tolerance to eliminate binding and keep things true.
Old 10-25-2016, 11:37 AM
Flash68's Avatar
Flash68 Flash68 is offline
Awesome score.
Yes it will.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 10-25-2016, 12:08 PM
cpd004's Avatar
Thanks for that info! So the centerlink needs to stay level at all times throughout the steering travel, correct?
Please keeps the pics coming...definitely appreciate them!
1971 Firebird
2017 SS
Old 10-25-2016, 12:19 PM
gerno's Avatar
Based on discussions I've had with Sutton, yes but I'm not the expert. Maybe after SEMA he will comment more about this, I know he's pretty busy right now. My understanding is that if the centerlink is changing angles that means your inner tie rod mount is moving. The location of this mount will directly impact your bump steer step as well as ackerman (I'm pretty sure) on the car. I don't have my notes from his class with me to confirm this.
Old 10-25-2016, 06:08 PM
Dave Pratt's Avatar
Dave Pratt Dave Pratt is offline
Gerno thx for the info on the welder.Just got in from work so I'll look it up...cheers
Old 10-27-2016, 10:09 AM
Good work, Steve. I know the feeling about stepping back. That's kind of why I've gone dormant on my build. I'm not giving up. I'm just not wanting to burn out. Good luck moving forward and making your March deadline!
Old 11-01-2016, 06:59 PM
gerno's Avatar
A bit more progress has been made over the last week. The LCAs are all welded up with shock mounts added. I also tacked up the sway bar which has been driving me insane. Finally figured out a configuration that has zero binding during suspension compression, zero steering or wheel clearance issues and tucks above the x-member during suspension compression. I'm going to wait to weld it up completely until the frame is fully complete.
Next step is to clearance the frame a bit more for the tie rods during suspension compression and full turn, check the alignment to make sure I didn't screw anything up and then start to fill in all the holes I cut in the frame.
Old 11-15-2016, 10:26 AM
gerno's Avatar
Small progress but progress non the less. Upper coil over mounts made.
Next step is to clearance the frame for the outer tie rods. After that I'm waiting on the new steering box and u joints to arrive and I'll double check everything including the alignment before I start final welding everything, reboxing the frame and adding additional gussets.
Old 11-15-2016, 11:21 AM
Your doing a great job!
