Old 02-03-2012, 08:55 AM
Macbuick's Avatar
Macbuick Macbuick is offline
Default and so on...
the rear LSD is inside with the right numbers concerning backlash and pinion...
The gearbox has received the kit and the TCI pan.
due to what is seems to be a wrong liquid cooler, all the aluminum parts of the cooling system is out !
some parts ready for powdercoating
SPECTRE funnels in the high beams...
problem with the carb fuel inlet, it hits the TA Performance intake...i have to order a 1" carb spacer and change the hat spacer from 2" to a 1" one...
the headers have been ceramic coated but haven't been polished, so i tried to but it was too boring...i will add header wrap to them....
[SIGPIC][/SIGPIC]
72 Skylark & 68 Pontiac Catalina+ 71 El Camino
Old 02-05-2012, 05:53 PM
67XR7's Avatar
67XR7 67XR7 is offline
Originally Posted by Macbuick View Post
Hi,
I have a dilema,
I have a B&M shifter for my Buick, in a first though i went to place it over my console, but it's too huge, so i could remove the cover and drop it inside the console and make a boot to fill the gap.
But i don't know if the result will be pleasant....
So i had another idea, buy another shifter : the B&M Unimatic which has a manual look and would perhaps better suits the console !
Here you can see the plate i made to suits the console and install 2 switches, fuel and ignition.
Let me know what you would do.....
THX
David
what is that center console out of?
Old 02-06-2012, 02:12 AM
Macbuick's Avatar
I bought the console on ebay some yeras ago, the seller said it's from a Cavalier, ......this is what i found on google : Chevrolet Cavalier LS 2003
[SIGPIC][/SIGPIC]
Old 08-27-2012, 11:25 AM
Macbuick's Avatar
Default build goes on....
time to fit the intercooler with some fabrications...
I had to cut the tubing and make some beads at the end of the tubes, I used a bead roller.
[SIGPIC][/SIGPIC]
Old 08-27-2012, 11:34 AM
Macbuick's Avatar
Default next
the jauge pod is in place =) fuel and boost pressure
next step , getting rid of the column shifter...
I had bought a tilt floor shifter column from a monte carlo (dixit seller) and I mixed the two comlumn using the monte housing in place of the Buick one...
job done....
[SIGPIC][/SIGPIC]
Old 08-27-2012, 11:38 AM
Macbuick's Avatar
Default on the floor
with my modified Unimatic shifter,
I built a mounting box to place it under my console..
the welds are as is as they will be hidden
[SIGPIC][/SIGPIC]
Old 08-27-2012, 11:42 AM
Macbuick's Avatar
Default Koni + SPC
Koni shocks are in place as well as the SPC upper arms.....in place of the CPP ones.
next step the eletricity, MSD and fuel pump.....
[SIGPIC][/SIGPIC]
Old 08-27-2012, 11:48 AM
Macbuick's Avatar
Default fuel....
sump tank is welded.....
I made a plate to bolt the fuel pump between the tank and the rear bumper...
I ordered a sandwich plate to place between the oil filter in order to have more holes to fit the oil pressure and T°....
[SIGPIC][/SIGPIC]
Old 09-08-2012, 12:20 PM
67XR7's Avatar
Looks like she's coming along great! dont forget the video of it running when on the road!
1965 Chevelle, Pm me if interested in wheel tool rental
Old 09-09-2012, 12:23 AM
Macbuick's Avatar
Thanks, video as soon as she hits the road ...
follow the updates :
https://lateral-g.net/forums/showthread.php4?t=35646
[SIGPIC][/SIGPIC]
