Old 05-25-2008, 08:29 AM
gearheads78's Avatar
gearheads78 gearheads78 is offline
Well guys it does not look like its going to happen. I am over the budget I gave myself and still short about $500.00 for some mis stuff I need to finish. I was fortunate enough to get myself out of dept last year and I refuse to go back in. In addition the powder coating taking an extra 8 days just threw off my already very tight schedule. I could just slam it together and still make it but I have come this far already I just don't want to cut any corners. My wife has been very understanding but my 2yo daughter is having I hard time with me comming straight home eating and going out to the garage every night for the last month so I need to spend some time with her.
I already have the time off for PT and some money set aside for the trip so I am going to supprise them both and spend a few days down in South TX at the beach.
On to project update........
When I went to assemble my rear E-brake assemblies I noticed I was missing two little pins. My guess is they fell through the screen when I had the harware cleaned up and zinc plated. The only way to get that pin is a 100.00 kit from GM.
I dicided to make them and it turned out pretty good. I borrowed one out of a friends Camaro to copy. I used 1/4" grade 8 bolts to make two new ones. I chucked the bolt up in a drill and ground off the head will a bench grinder while the drill was spinning to keep it uniform. I used a file while the drill was spinning to sneak up on the size. Then 180 sand paper and finally 400 emery cloth to polish the tips. My finished pieces are with in
.004 of the of what the factory ones are long. Few hours work was a whole lot better than $100.00 to get new ones.
After greasing up the front bearings and installing the hubs I slipped on the C6 rotors. I one side I could see a bad wobble. I put a dial indicator on it and it was .035 tolerence on the runout. I took that rotor to work to check it on a brake lathe and it was fine. Now I was thinking I had a bent hub so I but the indicator on it. Luckiy the problem was a high spot on the face of the hub. I few minutes with a hand file and it was level with the rest of the hub. Now the runout is only .004 on that side. Much better.
Only other thing I have done is finish the front suspension and steering. I ordered the wrong drag link. I did not know there were two different sizes. I ordered a 7/8 and need a 13/16. I thought to save time and $$ I cleaned up the original and installed it but it has a little play in one of the joints so its going to come back off. Now I need to oder a 13/16 link or find a pitman and idler for the 7/8 one.
The last thing I did Saturday was test fit a wheel to get an idea where to run the hard lines so the still clear the 9" wheels up front. I sure do like that last picture.
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
Old 05-25-2008, 05:55 PM
ScotI ScotI is offline
Attaboy for thinkin' about the supportive spouse & your daughter. You've done alot in a short time so take the trip w/the family. The car & the rest of us will understand.
Old 05-25-2008, 09:26 PM
I'm bummed but nothing I can do. Maybe next year the 455 will be done and I can have Power on Power Tour
Today was a bust. As far as the project. I spent the morning with my daughter and went outside mid day. I planned on building brake lines. After making one of the rear axle lines I went to flare the end. Just as the tool started to seat I heard a pop. The insert for the double flare broke :x
Only other thing I did was spend a few hours on the front calipers. I filed, sanded and smoothed all the machine marks and casting texture and flash. I can't wait to get these painted. They are one of my favorite things about the whole build.
Richard J.
Old 05-26-2008, 10:35 PM
SteveMcqueenRules's Avatar
SteveMcqueenRules SteveMcqueenRules is offline
I reall like this build. It is how I would do it. Spend the money on the right things and on a budget.
Love the wheels and the calipers.
You're gonna be hangin' on for mercy when I get this sucker rollin'- FALFA
Old 05-30-2008, 08:01 PM
If you loved the wheels before what do you think now.
Waiting on a new hydraulic flare tool to do my brake lines. I did get the wheels painted and mounted the tires today. I can't wait to see the body down over these.
Richard J.
Old 05-31-2008, 04:55 AM
ProTouring442's Avatar
Dang those are sweet lookin'!
Shiny Side Up!
Bill
Old 06-01-2008, 10:46 PM
Shiny Side Up!
Bill
Thanks I am pretty proud of them
Not too much to report today. I had to work most of the weekend but I did get in the garage a few hours tonight.
About a week ago I discovered I have a small problem as I was fitting up the rear brakes. The rotor was not centered in the caliper basket. After a little research on line I saw the other people are running washers or buying a spacer to bring out the backplate. Someone makes one intended for Camaros and Chevelles but it is 3/16" thick. I spaced mine out 3/16 with washers and it was too far. I get it very close to center on my Olds rear with .125" so I decided to make some spacers.
Now that I will bring the backplate out it creates another problem. I had thick spacers made at a machine shop to go between the factory bearing retainer and the axle seal and bearing. Now the spacer will be .125 too short. I'm not going to pay to have them made again so I made spacers for my spacers. Since I already have to cut a hole in the other spacers cut a second hole in the center first and then cut the outer ring. By doing it this way I am basicly making my bearing spacer when I cut the center out of the backplate spacer.
Here is the 1/8" plate marked up before cutting.
Here is the new bearing retainer spacers next to the machined spacer. It's hard to hold the plasma torch steady going arong the circle but they are close enough that a little time on the bench grinder they will be ready to use.
This is me cheating to make a nice straight cut with the plasma. Just clamped a piece of steal spaced away from my line so the torch cuts right on the line.
Here is the rough finished backplate spacer. Little bit of time with a file and it will be ready for a quick coat of paint.
Richard J.
Old 06-21-2008, 10:56 PM
I finally got a little done on the car today. After vacation I hurt my back and did not get anything done since. It still a little sore so I was going slow and taking it easy.
I the task I needed to accomplish is to build brake lines from scratch. i am switching to 3/16" front to rear line to match what was on the car the the brakes came off of. Pre-made lines only come in 1/4" so I just ordered 20' of stainless 3/16. I think it all came out good. I used the factory retainers and added a few of my own. The are Krugel line clamps I picked up at a local street rod shop.
I was origially going to run a 67 dual res. distribution block with a Wilwood proportioning valve. I changes plans when I found that Summit sells a block with a build in valve. I did not want to mount it showing in the engine compartment so I mounted it under the car. I made a bracket thar bolted to the original gear selector bracket holes in the frame.
Made a template out of cardboard to get an idea of what I wanted.
I then cut it out of 1/8" plate with a plasma cutter
After drilling, grinding, shaping with a torch in the vise this is the finished piece ready for paint
Finished in semi-gloss black and installed.
Richard J.
Old 06-21-2008, 10:57 PM
Here are the rest of the brake lines installed from the block back. I will try to do the fronts Sunday
Richard J.
Old 07-06-2008, 08:51 PM
Things for been going slow the last few weeks. My boss has been on vacation so I have been working extra to keep up with his duties and mine. Last weekend I selected to completly clean up and rearrange the garage instead of working on the car. It was something I should have done before I started but I was in such a hurry to get going I didn't. Its now laid out much better to tackle a big project like this.
Today I finally got a little work done. I am a little gun shy on my back still so I have been working slow and paying much more attention to how I move and bend.
I did lots of odds and ends that are not worthy of pictures. I did manage to build the front brake lines and get the motor/trans mocked up in the chassis to measure for the driveshaft. I still have to get the calipers powder coated and have the driveshaft built. Once thats done the rolling chassis can be finished up.
The boss did stop in and check on progress. Number one question from her has been "Daddy when are you going to finish the 'vertible" She is ready to start riding again.
When I built the rear brake lines my cheapie parts store bender got the job done. The the front I needed some sharper bends and much closer together than my bender is capable of. I scrounged up some 3/4" all thread and nuts to make up a quicky home made bender. It worked great.
Here is the finished front lines. I will wait for the body to be back on the chassis before building the feed lines.
One thing I was not sure about has how the rear crossmember was going to work out. After mocking it up with the tranmission it place I found out its going to be a cake walk. I will be able to use one exhisting hole and drill one new hole in the frame braket on each side.
Even thought it was only temporary to measure for a driveshaft it sure was nice to see a motor sitting in place.
Richard J.
