Old 07-20-2011, 10:22 PM
rwhite692's Avatar
Thanks very much guys, I feel better about it now.
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 07-21-2011, 09:52 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Yeah, I had 5500 miles on mine (complete 9" from DSE) and it never made any noises. I've got a little under 8000 miles now with the same center section, but floating axles and it only ever clunked once after pulling away from a stop on a hill. You'll be just fine
Matt
Old 07-21-2011, 10:08 AM
rwhite692's Avatar
Thanks Matt!
Data points like that, (your 8K miles, and Payton's 4.5K) are great to have.
My Lateral-G Page
My Shop Build:
Old 07-25-2011, 10:12 AM
rwhite692's Avatar
A little update again, since I've managed to get a few things done here and there.
Mounted up the radiator and intercooler. These pics will look quite familiar to Scott and Jody, LOL.
I still have to order my Vintage Air stuff and get my condenser mounted as well.
The RS headlight doors won't hinge open all the way due to the intercooler but I already knew that issue was coming. I am going to fab up a mount for the door faces so that they can be popped in/out.
Made up some closeout panels out of 6061 sheet for the fenders where the 4" tubing will pass through to the air filters. They still need fine tuning and bead rolling but, you get the idea.
I decided to run a wilwood pedal assembly w/balance bar and the small masters, so I made a 3/16" plate mount/panel for that, and sank it into the firewall. It's just tacked in place for now.
For the bottom section I made a plate as well. The lower section is sank (sunk?) into the firewall about 3/8" further than the top section.
Once I measured the angle of the dangle, I jigged up the plate and bored an angled hole through it. I found some nice SS tubing with an ID a tick over 2", so the column tube is a nice slip fit inside.
I am going to drill and tap the tube for some set screws, and also cut a 3/32" groove into the ID of the tube at the lower end, to receive an o-ring to keep any water/dirt from getting into the tube.
Well, that's about all for now. time to clean up. -Rob
My Lateral-G Page
My Shop Build:
Old 07-25-2011, 11:12 AM
Flash68's Avatar
Flash68 Flash68 is offline
Really like that last picture. Super clean car coming together in a super clean space.
Cool to see you making good progress again.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-25-2011, 11:34 AM
torino420's Avatar
torino420 torino420 is offline
Nice progress, love the shop too! I drool every time I drive by your place.
69 Torino GT Formal Roof
420" Windsor TKO600
Old 07-25-2011, 12:22 PM
Ron in SoCal's Avatar
Wut he sed...
Great update Rob. Your plan is falling together nicely and that innercooler looks right at home...
Ron in SoCal
69 Camaro in progress
Old 07-25-2011, 05:33 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Very nice. Great to see the updates. Looks like a great build.
Old 07-25-2011, 06:02 PM
coolwelder62's Avatar
Rob,Look's great.
Old 07-25-2011, 06:27 PM
Rick Giles's Avatar
Rick Giles Rick Giles is offline
Wow that's some good looking fab work, Rob!
