Got another 78 T/A I was resurrecting on its feet and out the door. Time for this fellow to get some lovin'. While the original electrical system functioned, it wasn't pretty. It didn't flow well either. I also wanted to add some circuits & simplify some circuits as well. Also wanted to have relays. Something present in 1978, but not widely used like todays cars.
Some Circuits I added/ altered:
-In-tank fuel pump from 4th gen and 14 GA wire from pump to relay
-integrate O2 ECU into Projection 4 ECU
-Add triple stage lighting system. not sure if I will like it, we'll see.
[outer lamps have high and low, stage 1 & 2. inner lamps are super high (100 W H1) , stage 3)] each high has its own relay and switch. Used a 79-81 column activated switch for one and the stock floor mounted switch for the other.
-Spal dual electric fans w/ module
-Mallory Unilight dist and E-coil
- relocate all A/C relays and electrics to pass side of evaporator box.
A big issue I had was where to affix the relay box, coil and modules so they would not look cluttered, yet be accessible. For now, I decided not use the stock cruse vacuum unit. may relocated or find a better solution in the future. Stock electronics and controls are still on car and not in the way. the driver's firewall under the fender provided a nice place for the 93-97 f body relay box and fan controls.
I liked this box as it is simple, compact and has room to grow w/o have excess. thanks to forum member TnBlkC230WZ, I was able to locate the proper terminals for the box as well as other components in my system. Mouser.com has what you need, you just need to know what it is you need. I modified the stock late model f-body relay box bracket to suit my needs and locate the box some the fuses and relays would be accessible w/ the fender on the car. I can even affix a mini Mag light behind the box and the firewall if needed. or a place to 'stash' stuff'.
the fan modules can be accessed from the top w/ the fender installed. its tight , but will work.
Backing up a little, I had gotten the car to run and a roughly laid out wiring harness and jumper cables to test the circuits. I took that down and cleaned the rats nest up and tried to hide it as much as possible. Ordered some wire braid from painless and order more from their supplier which is 12 minutes from my house. buy direct and $ave.
. wirecare.com is the retail outlet. good stuff.
with the newly critiqued wiring and component installation, it was time to see if all systems still functioned. Sure enough, all is well. Took the stock HEI out and put in the unilight and hooded up the coil and receive no spark...booo:doh:
I noticed the E-coil getting warm so I unplugged it w/ the batter to let it cool and tried again. no spark. after some test, I am looking at what could be a faulty module. this unit I bought used from a friend for 40 so I am am still ahead of the game if it is bad. It has the E-spark in it . may replace w/ basic unilight if it test bad.
need to beatify teh T56 harness and wire the Cable X to complete the electrical system for now.
I have to add the braid to the wires yet
Some pictures of the relay box area.
93-97 F body box
starting some wiring
test fitting on bracket
some wiring
connecting box to body wiring
El fin
not sure what to do w/ the extra fan wires. they are not used or optional. I'll prob cut them and cap them. the positive terminal will get a protective cap to prevent shorts.
I am also drafting a new wiring diagram from the car as a bunch has changed. using Autocad and scanned original diagrams. I will have a completely digital wiring diagram for this car when I am done. will keep it w/ the car for future reference. I tried to keep the wire colors meaning full such as: red - batter direct, yellow - battery hot after fuse, orange - ign hot..ect...
