Old 01-24-2010, 08:14 PM
TravisB TravisB is offline
Originally Posted by elitecustombody View Post
I'm sorry that my English is second language which I learned besides Deutsch and Russian,I can tell you more than half Americans that were born and raised in USA can't spell to save their life, but what does spelling have to do on subject at hand?
We are so far off the subject at hand its not even funny. All the poor guy that started this thread wanted to know was how to fit his gaps.
Step 1. align the best you can with hinges, latches, bolts
Step 2. decide if thats good enough
Step 3. weld and metal finsh gaps to your liking
Step 4. skim coat with filler
you can beat, pry, pick, move, pull structure tell your blue in the face..... you wont get oem style gaps 1/8-3/16 with out some filler and a welder.... thats it the end I will argue that point forever. I dont know how to say have a good night in Deutsch or russian .... but good night
Kenny Davis Hot Rods
Old 01-24-2010, 08:31 PM
elitecustombody's Avatar
AMD is the closest thing to OEM,in some cases thicker gauge metal with nice crisp lines ,give it try next time ,AMD has alot of metal for 1st gen.even complete aluminum front and deck lids
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 01-24-2010, 08:46 PM
Sunkistcamaro's Avatar
Sunkistcamaro Sunkistcamaro is offline
Thanks, I'll have to check them out.
Bill
[email protected]
Old 01-24-2010, 10:10 PM
70rs's Avatar
70rs 70rs is offline
Glad to see this thread worked out so well for the OP.
Eric
Old 01-24-2010, 10:55 PM
The WidowMaker's Avatar
well, i actually got my answer in the first few posts, so it actually worked out. hopefully it will get cleaned up some since i know im not the only one looking for answers and id rather it not get locked.
so some new questions since everyone is now looking at this thread....
any more pictures of gapping?
any videos of you guys blocking over the gaps?
any good videos of blocking in general? especially lines????
everyone says to block up to a line but not over it. but then theres no way to get it crisp. do you just mean not to roll it once you get to it? hard to explain, but i sharpen the edge of wood by running a sander or plane partially over the edge, but i keep it parallel to the surface im working. if you dont, you will round it over. is this how you guys block, or are you seriously stopping say 1/4" from any body line?
thanks again, Tim
and please mods, clean up but do not lock.
"The WidowMaker"
Old 01-25-2010, 04:52 AM
68protouring454's Avatar
tim, i like to put a piece of tape on one side of the line, and work one side, then tape side i just worked and work other side, i do this on the 69 camaro fender and door line and rear quarter line, its helps a ton in keeping the lines as straight as possible.
you can block over them, however like you mentioned do not roll over them.
I like to use a sponge block to dull line to what i want, you can get them too sharp.
guys, I would be very surprised if amds metal came from anywhere different then goodmarks.
Jake's Rod Shop
Old 01-25-2010, 04:54 AM
Originally Posted by Sunkistcamaro View Post
Is AMD's sheet metal that good?
I worked in a restoration shop for 6 years and never seen repo panels that good.
if amd's metal was so far superior, we all would have heard of it and been using it by now.
aftermarket panels fit how they fit.
Jake's Rod Shop
Old 01-25-2010, 06:59 AM
OP, use good masking tape to mark the lines and block up to it,when done blocking, lay another strip of masking tape right up against the old tape and block the other side,when done blocking,you shoud end up with very sharp and crisp line,if it's too crisp,roll over it few time to your liking
use straight edge wherever you can to make sure you have no dips in the panel.That can happen if you use short blocks, so try using long blocks where possible, I recommend 2x1/4x24 aluminum stock wrapped in masking tape few times,or stop by Home Depot and pick a paint mixing paddle. I never trust foam blocks,even if they cost $50 a piece ,when blocking, do not push,let the sandpaper do the work and after few strokes,change direction
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
Originally Posted by 68protouring454 View Post
no, a common issue with goodmark trunks is there too small for the hole width wise. the gaps were arounf 7/16ths. we sliced the quarter 1/16th from edge, moved over till we had 3/16ths strong gap and measured, then used shear to shear filler piece that we but tig welded in using silicon bronze. metal finished to 80 grit and body worked.
goodluck
Without a tig welder, should I stay away from silicon bronze? How do you use silicon bronze to seal / fill the joints between the tulip panel / qtrs and qtrs to rear body panel? Can I use a mig? if so size wire?
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 01-25-2010, 08:11 AM
use .023 mig wire.er70s
we use silicon bronze as it requires alittle less heat then er70s filler, we use .035 tig filler rod but thats as small as i can get it. It metal finishes as nice or better then steel.
Not sure I follow you on the sealing of tulip panel etc. we usually use fusor metal glue(108 or 110b) for the tulip panel to quarter panel seams, you can clamp them underneath fairly easy. provides a very nice seam for seam sealing before paint. we then plug weld the window seam and the trunk weather strip seam, if leaving trunk weather strip piece in place we will glue that seam and use 3 kleckos to hold it together
Jake's Rod Shop
