Old 12-03-2010, 09:05 AM
youthpastor's Avatar
great thread
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 12-06-2010, 10:18 AM
Bobs 67Camaro's Avatar
Bobs 67Camaro Bobs 67Camaro is offline
Has anyone been in a TCI car with the softer rate springs? When tested, they were 450/325# (back in 09), now they are 350/250? Would it be similar ride quality to the speedtech 450/220 set-up?
Old 12-06-2010, 12:51 PM
BRIAN BRIAN is offline
I think the problem with the whole subframe debate is people buying them for the wrong reason or buying what is supposedly talked about as being the best thing since sliced cheese. Remember when if you didn't have a Wayne Due frame you couldn't turn a corner?? But then he mysteriously disappeared.
I know there is probably no way to do a part to part comparision but a guide with real answers side by side would help.
Weight of frame fully loaded?
Ride height adjustment?
Total caster and camber adjustment?
what type and style of bushings used?
What type of rack?
What brakes adaptable to spindle?
Type of sway bar and adjustability?
Those are just a few. If you do not know what you need out of the above you are probably just buying because it is a shiny new expensive must have part. Let's not forget many a race won modifying stock parts. The subframes give you the ability to get to that point faster and easier.
Would I buy a subframe that uses cheap ultra small Mustang 2 bushings? No Would I buy a subframe that uses heim joints throughout on a real driven car? No.
There is no winner unless you know what you want. If you want a slammed on the ground never ran car there are also plenty of options.
Old 12-07-2010, 04:26 AM
Brian,
What suspension systems do you run? (what car do you have)
What purpose does you car serve, and why did you choose the parts that you used?
Old 12-07-2010, 08:58 AM
slow4dr's Avatar
slow4dr slow4dr is offline
Have you ridden in a stock suspension LX or LY SRT8? They have a very comparable ride quality with the 350/250 springs.
'04 IS300 LS3/TR6060 swap in process
'89 Plymouth Colt GT - 411WHP, 2490lbs & 32mpg
'06 Magnum SRT8 - AFE S2, 3" Flowmaster catback, Diablo Predator (KIA by a drunk driver 10-25-13)
63 Nova 'Low Budget G-Machine' *SOLD*
Old 12-07-2010, 09:25 AM
Slow4dr,
I have not ridden in one, but would imagine the ride is firm, but compliant. Not something that would wear on someone too badly.
I also do road trips with my car, so a decent ride is important to me (300-500 miles in a weekend).
Thank you for the input, I appreciate it.
Old 12-07-2010, 10:43 AM
GrabberGT's Avatar
GrabberGT GrabberGT is offline
I have Total Control Products Front Coil-Over suspension and the TCI torque-arm rear with springs rates 450/250. Though I cant yet comment on the performance driving aspects of the ride, the cruising side is comfortable. My cars weight is 3300lbs with driver and a full tank of gas with 51/49 split if that helps.
Chris
Its not a Vega!!!!
Total Cost Involved - Total Control Products - Gateway Performance - Fatman - MaverickMan Carbon
Old 12-07-2010, 03:32 PM
Have you been happy with their coil overs (did you get the singles or the doubles?)
Old 12-08-2010, 08:42 AM
GrabberGT's Avatar
Singles. Still getting to know them.
Chris
Its not a Vega!!!!
Old 12-08-2010, 02:08 PM
GrabberGT,
Are you running the TCI Coil overs? If so, how do they compare to the ridetechs or QA1's?
