Old 06-05-2010, 06:29 AM
AWDPete's Avatar
AWDPete AWDPete is offline
I believe I have narrowed down the list of needs/wants pretty well but I could still use some suggestions on the following:
Coilover LCA - strong and light
Adjustable hollow anti-roll bar
Full coilover, not a car specific fitment. Varishock, Afco, ????
I understand that with the stock sub the wheel and tire will be a little narrower than can be fitted with an aftermarket sub. What is generally considered to be the max size fitment?
Rocks!
PeteH
Baraboo, WI
https://lateral-g.net/forums/gara...vehicle&id=121
Old 06-05-2010, 07:15 AM
Originally Posted by AWDPete View Post
My only question here is who's arms are "geometry corrected"? The actual changes made by the various aftermarket arm builders seems to be a secret! They list the material they are made of, which bushings and balljoints they use but they don't specifically list what the change in geometry will be (did I miss it somewhere?). Reading many other posts in this forum it seems you would be the man to ask
Sorry, my post alert is not working for this Lateral G so I missed all this. Hotchkis arms are now geometry corrected meaning the upper ball joint is moved back and the lower ball joint is moved forward for more caster without moving the wheel back in the fender well.
As for drilling new holes or using a tall ball joint. All you doing either way is changing the pivot point of the control arm shaft in relation to the ball joint. Weather you move the shaft down or ball joint up, you get the same basic effect. you simply want that upper arm pulling the top of the tire in as the arm moves up. Drilling the holes is free but only works with aftermarket arms without center bracing in the arms.
Frank Serafine
Old 06-05-2010, 07:39 AM
I spend all day talking to people about this very subject. People wanting the best, feeling pressured to HAVE to do a aftermarket subframe, or go to welding school modding their subframe. As someone mentioned earlier in the post. Once you change control arms and improve camber gain and caster and install a good steering box. You enter the land of diminishing returns.
For a street car that raises a little hell on the street, is casually autocrossed, goes to a couple track days and runs 8/10ths. The difference in performance of a Mildly modded (G mod, A arm, 600 Box, etc) VS Very heavily modded subframe (Coil over conversion, fully welded) or even high end aftermarket subframe, is at such a high 10 / 10ths edge, most uf us will never find that edge and find the performance advantage if any.
Most of us spend 100s of hours and THOUSANDS of dollars on paint and simply will not push the car 10 / 10ths, or worse, 11 / 10ths anyway. So we will never realize any performance difference even if there is one. the perfect example was at the midwest Muscle Car Challenge this past weekend. Over 40 cars were there and 5 were "racing" for the win. the others wewre all having fun pushing there car about 8 / 10ths. I know I was there with the Bull Run Racer and it has a 4000 mile Rally (Bull Run 2010) to do in 5 weeks, and I was not really interested in wading it up. So I ran 8 seconds off the winning pace and had a ball! 90% of the other guys felt the same way.
If you do...........
Upper and lower geomtry corrected arms, I would do 1 piece arms. (I do not like light weight anything on a street car)
A good coil spring and seprate shock
Good hollow sway bar
600 Steering box
Some tie rod sleeves and new tie rods / idler.
Redrill upper arms mounting holes
Your going to make a amazing difference you can really feel.
IF, Big I F, you can do your own cutting and welding and IF you enjoy the fabrication, the coil over conversion would be cool, but I promise the advantages are small if any. And it takes a experianced racer to be able to read the feedback to make the ajustments needed to make it better.
If you have to pay a shop to do the coil over conversion kit, your going to spend way more money then it is worth.
Frank Serafine
Old 06-05-2010, 10:41 AM
AWDPete's Avatar
Hi Frank, I appreciate your input.
The maniac in me says I NEED ATS spindles, dbl adjustable coilovers, Z06 brakes, etc. but after reading through this thread and taking a good hard look at how I will ACTUALLY use the car. Your advice is sound.
I will say this because you asked, I can fabricate and I do enjoy doing so. My shop is pretty well equipped, I even have a mill and a 9" South Bend lathe Right now I have more time then money, and I'm in no hurry.
I will still run some struts because I think they will be help. My thought with the coilovers was to have two sets, one for street cruising and the other for track events - I could drive to the track, jack it up, unbolt a couple of bolts and swap them out. That way I wouldn't have to live with a 'race tuned' setup all the time. The reality is I don't think it will happen enough to justify the cost. I do enjoy the tuning aspect and getting it dialed in rates very high on fun-o-meter!
While I have no problem with Hotchkis parts (other then the weight?) and I see they have a pretty well thought out design they are not exactly inexpensive. Looks like around $1300 for the arms?
What are your thoughts on the Musclebar? I'm leaning towards a G-Bar for the rear.
I saw (and listened) your vid of the Camaro with Edelbrock LS swap & exhaust - I like!
Thanks for your help Frank, I really appreciate it!
PeteH
Baraboo, WI
Old 06-05-2010, 01:36 PM
James OLC's Avatar
Rocks!
Control Arms - SpeedTech high clearance (assuming from your final question that you looking for the largest possible front wheel/tire)
Anti-roll bar - Hellwig Products has some great adjustable hollow bars
Coilover - budget dependant but I would take a hard look at the new RideTech shocks.
On my stock subframe I am running 275/35-18s on a 9.5" rim. I think that there is room for a 285 with a little bit of work.
I think that the OneLapCamaro shows some of the potential of a stock subframe. While I can see advantages to an aftermarket sub (mostly wigh respect to tire size and weight) I don't think that a well built stock subframe is a major handicap.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 06-05-2010, 02:58 PM
The discount on the hotchkis bring them down to about $1100. Speedtech also are that price range, both are great.
I like Helwig or Hotchkis for sway bars
Go for the Chicane kit if you enjoy the fab, and one set of shocks / springs should be fine.
Frank Serafine
Old 06-05-2010, 07:48 PM
AWDPete's Avatar
Thanks James, there is no question that your car is very capable!
So how do the SpeedTech's compare to the Hotchkis as far as tire clearance? I do like the adjustability you get with the Hotchkis but if I have to give up tire size it might be a deal breaker. What hits first, upper or lower?
How would these bars work (rate wise) with the G-bar rear setup - would I use the sliding link or the splined end bar?
I will take a look at the Ride Tech shocks, price looks good.
Thanks Gents!
PeteH
Baraboo, WI
Old 06-05-2010, 09:40 PM
CarlC CarlC is offline
Who in their right mind would put a 285 front tire on a stock subframe 1st gen?
Plans often change after the first "completion" and may effect your long-term outlook. I like reversible. It allows for new things down the road.
Don't worry about the stock wheel bearings. They are just fine for what we are doing.
http:www.vaporworx.com
Old 06-05-2010, 09:47 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Oh, I know, I know - no one!
Old 06-06-2010, 03:39 PM
coolwelder62's Avatar
Speedway motor's has some budget tubular a-arms for the 1st.gen's around 650.00 for upper's & lower's.They also have quick ratio steering boxes alot less than everybody else. they have springs, afco shocks,brackets.Alot of useable parts at lower prices.www.speedwaymotors.com or 1-800-979-0122.
