Old 03-09-2011, 07:51 PM
G-Body's Avatar
G-Body G-Body is offline
Default Pro Street Hot Rod progress pics!
Wussup guys i had a post up on here but realized how old it was thought id start a newer one!
A lil up date on the car starting to make some progress heres some random pics! later George
By profleetline at 2010-11-18
By profleetline at 2010-11-19
By profleetline at 2010-10-08
By profleetline at 2011-03-04
By profleetline at 2010-11-09
Old 03-09-2011, 08:33 PM
The car looks great. I love the way you did the hood. What have you got planned to do next? More sanding??
Old 03-09-2011, 10:02 PM
G-Body's Avatar
Yep engine should be back soon getting it all buttoned up and going to get it in and test fire it get wiring and fuel system in and make sure it all works before body comes off the frame most of the body work is completed except blocking and sanding the inner fender wells and bottom of hood, and it can go to the paint shop and the frame to get blasted and it will be smoothed up with the rear end and will be painted body color aswell.
Also picked up a few last things to get it fired up.
By profleetline at 2011-03-02
By profleetline at 2011-03-07
By profleetline at 2011-03-08
Old 03-09-2011, 10:07 PM
Alot of nice stuff right there. Those gauges are sweet. Is that alternator solid to the chassis? how does it work?
Old 03-09-2011, 10:20 PM
G-Body's Avatar
Thanks yeh its solid im running solid mounts and a polly tranny mount. so no give plus running an electric fuel pump it cleared up the bottom right side of the block and you can only get a left side low mount alt. bracket but i want to run my power steering pump on the left down low, soo i made my own mount on the right to keep all the assec. way low on the block to clean up the engine and the front of it!
By profleetline at 2010-09-24
By profleetline at 2010-09-25
By profleetline at 2010-10-20
By profleetline at 2010-12-10
Toggle panel switches are hidden by visor when flipped up you cant even see them! and quad gauge is pretty much where the mirror would be so out of the way but yet easy to see and it will be molded into the header panel above visors.
Old 03-09-2011, 10:28 PM
Nice idea on the alternator. The motor looks great too.
Old 03-09-2011, 10:08 PM
G-Body's Avatar
By profleetline at 2010-11-11
By profleetline at 2010-09-21
Old 03-09-2011, 10:11 PM
Very Nice work.
Old 04-13-2011, 10:15 PM
G-Body's Avatar
By profleetline at 2011-04-13
Old 04-14-2011, 08:35 AM
Wow that looks great in there! Is it in for good? The work you did on the firewall and body looks great. Keep the up dates coming. It looks Sweet!
