Old 04-27-2011, 02:58 PM
GPR's Avatar
GPR GPR is offline
Default LS1 powered 1999 S10
We are painting a shop truck for our neighbor Current Performance Wiring. www.currentperformance.com. It will be powered by a 2004 GTO LS1 with an automatic. Front suspension is TRZ control arms with leaf springs and Caltracs in the rear. Front tires are 255/40/18 and the rear 295/35/18. We modified the rear bed and did away with the step in the rear. After we started the project we found out there is now a steel kit available. The original bed had some rust around the wheel wells so we used the top part from the right side on the bottom of the left side of the new bed.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 06-18-2011, 11:10 AM
GPR's Avatar
GPR GPR is offline
Here is the engine and trans
Rusty Gillis
Port Richey Fl
Old 06-18-2011, 11:16 AM
GPR's Avatar
GPR GPR is offline
We are back working on this project. Brian finished welding on the bed
Rusty Gillis
Port Richey Fl
Old 06-18-2011, 12:53 PM
awr68's Avatar
awr68 awr68 is offline
That's a sweet project! I'm a fan of sport trucks! I like all the work that has been done so far!
Tony
'68 Camaro
Old 06-19-2011, 07:31 AM
GPR's Avatar
GPR GPR is offline
We modified the cab a little
Rusty Gillis
Port Richey Fl
Old 06-22-2011, 05:49 AM
GPR's Avatar
GPR GPR is offline
The cab had a little rust in the lower firewall on the right side that was cut out and repaired than we epoxy primed the cab
Rusty Gillis
Port Richey Fl
