Old 02-03-2012, 03:32 AM
RodZZilla RodZZilla is offline
Originally Posted by RS-Perf View Post
The engine that is going to power this beast! a 572 with a F2 Pro-Charger looking to make 800 - 900 HP.
That is awesome!
Is that a GM crate w/a Procharger added? What is the EFI set up?
Old 02-10-2012, 02:48 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Originally Posted by RodZZilla View Post
That is awesome!
Yes, it is a GM Crate 572 with a F2 Pro Charger. The EFI is an Edelbrock intake with Wilson elbow and throttle body. it will be running a Big Stuff computer
www.roadstershop.com
Old 02-10-2012, 02:51 PM
Supporting Vendor
RoadsterShop.com
We have been making great progress on the metal work on this truck as well.
Before: large dent in the lower section and the tail light surround was distorted and rolled in from a collision:
After: like it never even happened.
Old 02-10-2012, 03:00 PM
Supporting Vendor
RoadsterShop.com
We are just about finished with the passenger side quarter panel as well. Here are a few shots along the way showing the progress.
We started by making a set of dies for the Pullmax to duplicate the lower bead in the suburban body line.
We then created the main panel section to replace the rotted out areas. here is it test fit over the existing rust.
A rear section was then shapped to form the leading edge of the wheel opening.
Once the fitment was finalized, the two new panels were welded togetehr to create a single panel.
Old 02-10-2012, 03:06 PM
Supporting Vendor
RoadsterShop.com
The rotted out section was then cut off the truck to reveal a nice foam inner quarter. I think this thing would have easily float with all the foam that we found inside!
The original panel next to the new panel. The new panel has the rear section of the original wheel opening attached to it. The center wheel opening portion of the new panel was lengthened to accommodate for the stretch in the wheel opening that we did on the other side of the truck.
The new panel being welded in place. We should have it all metal finished out early Monday.
Old 02-10-2012, 03:54 PM
DBasher's Avatar
DBasher DBasher is offline
Nice work! You guys make it look so easy.
Dan
Old 02-10-2012, 06:00 PM
Wow. You guys kick arse and take names huh. You must have an army of fabricators to get that much done on so many projects at the same time.
Can't wait to see more.
John
'71 Nova (Build thread)
FFR Roadster
Old 02-10-2012, 07:23 PM
Musclerodz's Avatar
What plastic is that dye made from? Delrin or something harder?
Mike Redpath
Musclerodz & Customz
facebook page
Old 02-10-2012, 10:06 PM
I love to see your posts. Awesome fab work.
Old 02-11-2012, 10:42 AM
That's going to be one sweet truck Phil!!!!
What's the story with the twin turbo camaro drag car????
Jeff Allen
J2 Speed and Custom
