Old 09-12-2012, 09:40 PM
Vetterodder com Vetterodder com is offline
Jim
That is one wicked ride!!
Old 09-15-2012, 09:19 AM
The body work continues on the 64 Convertible.
A nice touch is the POWERED hood lift now being fitted
Mike is also working on the gaps to insure the perfect fit and finish. In these pictures you can see the work being done to the front end in conjunction to the headlight buckets so that the fit and gapping is just right
Now that the rear wheel wells have been custom made to fit my wheels, allowing the folding convertible top to fit in place, the body is once again off the Street Shop Chassis to continue the body work
Starting from the bottom, Mike is smoothing out the underside of the wheel wells:
From my last conversation with Mike, the Corvette is nearing the point for the primer to be sprayed!!
Old 09-21-2012, 08:46 PM
The Roadster body is nearing completion. There are many hours of hard work to massage the fiberglass back to perfection. If all goes well, it will be in the paint booth within the next 7 to 10 days (doors and deck lid will be fitted to finish off) !!!!
In the meantime, I am working on the restoration of the interior dash items. I began with the glove box door restoration.
The chrome surround is in decent shape so I spent a couple of hours carefully masking the chrome, particularly around the edges. While not a hard task, it is a tedious one.
Here are a couple of pictures of the door masked with the old paint removed:
Now in Primer:
And finished with SEM Euro Trim (a satin black finish);
With the paint completed and the other parts back from black powder coating, it was time to re-assemble the glove box door with the new aluminum piece and emblem.
Tomorrow, the shift console will be masked in preparation for paint. And, if I have the chance, the chrome shop has finally finished my dash cluster so I may run up to pick it up first thing in the morning.
Dan
www.vetterodder.com
www.facebook.com/vetterodder.com
Old 09-28-2012, 06:25 PM
Now that the rear floor has been completed, the interior cabin has been sprayed with Lizard Skin for both ceramic (heat reducing) and sound deadening using both products as allowed by the manufacturer. The underbody will receive the same treatment with exception of the wheel wells that will have a smooth black finish.
The chassis has just come back from the muffler shop. Thanks to fellow Corvette forum member PW2006 for sharing his ideas from his 63 Roadster RestoMod. The pipes on my 64 are 2.5” aluminized and custom bent to fit the Street Shop C6 chassis. My concern from the onset was getting the pipes over the rear end but as you will see from the pictures, the guys were able to achieve it. From the rear, Magnaflow stainless steel mufflers are used and will later be finished off with 2x2 Magnaflow stainless tips that will come out the center of the customized rear valence.
Here is a neat shot of the body off the chassis. The body will be painted within a week or so now that I have decided on the color – VICTORY RED (Corvette color).
Old 09-28-2012, 07:38 PM
I love this build! Awesome.
Old 10-05-2012, 10:07 PM
While the body is finished at Mike Coletta’s shop, I continue to work on the trim items. The new shifter center panel arrived. I have masked the chrome trim and applied the primer and satin black paint.
The new Raingear windshield wiper motor was mounted inside the firewall as you can see from this picture:
And (drum roll please)…….
The painting begins! As you can see, the Victory Red is being applied to the underside of the hood and deck lid as well as the doors
Old 10-06-2012, 08:43 AM
pw2006's Avatar
pw2006 pw2006 is offline
Looking good!
Rob
69 Camaro PT project- LS3/4L70e, Budnik's, Ridetech, Speedtech, Wilwood, DSE tubs, 4 link, shortened Moser 12 bolt- in progress
Old 10-06-2012, 09:31 AM
I'm typically not a fan of red but this Victory Red is turning my head. Good color choice. Do you plan on a black stripe for the stinger hood?
Old 10-06-2012, 11:56 AM
Of course!! A nice gloss black for the stinger.
Thanks for the comments.
Old 10-08-2012, 05:34 PM
Well, after the much needed body work, primer and often under-appreciated block sanding, the time has come to squirt the Victory Red on the body. Without further ado, here is the 64 Roadster after paint (cut & buff to be done next).
Mike – you have outdone yourself!!
