Old 09-11-2012, 06:42 PM
coolwelder62's Avatar
some shots of the RideTech 4-link componet's,
Old 09-11-2012, 06:49 PM
Chassis bracing 2"X.120 wall round tube bent to follow the contour of the floor pan.Aprox. ride height/before shock mount were built.
Old 09-11-2012, 06:55 PM
Trying to keep the Exhaust alittle above the lowest part of the frame.
Old 09-11-2012, 07:05 PM
Alot of thing's are just tacked welded during the mock up part of the build.Once I am sure everything is going to work togather I will finish welding. Frt. and rear sway bar's showed up today.
Old 09-11-2012, 07:14 PM
Looking good Scott!
Did you build or buy those shock mockups? I just picked up a swedged tube set last week from Speedway but your setup is a lot more adjustable.
John
'71 Nova (Build thread)
FFR Roadster
Old 09-11-2012, 07:18 PM
Originally Posted by BBC71Nova View Post
Looking good Scott!
Speedway Motor's sells these shock mock up pcs.$59.99pr.Totally ajustable.Keeps me from getting weld spatter all over the shock's.
Old 09-11-2012, 07:28 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Looking good Scott. That is a massive tire under a Chevelle!
www.roadstershop.com
Old 09-11-2012, 07:42 PM
Thank's,Hope I can pull it off.
Old 09-11-2012, 07:57 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Car looks great Scott looking forward to seeing you complete this one.. Still my all time favorite build you did was the Sunoco 69!
Cris Gonzalez
Old 09-11-2012, 08:04 PM
Thank's Cris.I really loved that car also.Just to poor to keep them.My son Brandon and I are getting started on a 71 Sunoco Javelin build.It should be the same kind of theme.
