Old 01-19-2014, 07:56 PM
SSLance's Avatar
SSLance SSLance is offline
Post
As long as it quits leaking, it's all good!!!
Sure seems like the seal should help anyway.
Lance
Old 01-26-2014, 12:30 PM
SSLance's Avatar
This weekend I was able to finish up the performance minded wheel alignment, reset my pinion angle and bolt the street tires back up and run down to the car wash to rinse the layer of shop dust off the car. During the test drive I noticed a bit of interference coming from directly under the console and pretty much knew what it was right away. Between lowering the pinion angle 2 degrees and a slight raise of the body from the frame, my drive shaft loop was now just a bit too close to the drive shaft. With the car back up on the crib stands (Man, I've used the heck out of those things since building them) a closer inspection revealed that the loop was just a bit off center and just a bit too close to the yoke.
A couple of large washers were used to space the loop down a bit and that did the trick.
Another longer more intensive test drive proved the fix worked, no more interference.
It was in the 50s outside and sunny, which is warm but not really summer weather. The ride started out a bit springy I'll call it. As with most ride characteristic changes, they were more evident from the rear of the car than the front. There seemed to a be a bit more of a bounce after a bump from the rear than before. The more I drove it though, the better or closer to normal it got. Could have been just getting more heat into the tires or possibly even a little bit of a break in period on the body bushings.
The front felt a little bit different also, but I also made a pretty drastic change to the wheel alignment (-0.6 to -1.6 camber) which I'm sure had an effect too.
My GoPro battery was dead so I couldn't do any data acquisition but it's on the charger and I still might get another test trip in the books this afternoon yet. Plan on checking the front frame horn flex under hard cornering as well as pinion action under hard acceleration, braking and turning.
Overall though, I can not complain about any extra NVH from the Polygraphite Body Bushings. There may be just a touch more feeling from the smallest of bumps transferred through to the driver's seat, but nothing that a pound or two of pressure out of the tires wouldn't alleviate if it really concerned someone. Overall, I'd call the project a success.
Lance
Old 01-27-2014, 01:31 PM
SSLance's Avatar
Was able to grab a bit of video today...check this out.
Kind of a big improvement don't you think?
Surely that improvement in rigidity HAS to help with the steering input feel on the autocross course, right?
Lance
Old 01-27-2014, 08:15 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Great video Lance... big difference with the new Polygraphite Bushings.
I remember when I changed out the stock rubber body and core support bushings on my Camaro with solid aluminum and went for the first drive... it felt like a different car. The steering felt so much more precise.
I wouldn't be afraid to go with aluminum in the future. I didn't notice any excessive harshness in the ride when I switched... it just gave the car a much tighter, more precise feel in straight line and cornering.
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 02-04-2014, 01:16 PM
SSLance's Avatar
Snow day = Shop day
Since I'm going to run street tires full time this summer, I had to find a way to get my billet wheels looking nice again and more importantly keep them looking that way.
First up, cleaning them up and polishing them. Brake N Parts cleaner on a rag was used to clean the back sides of them up of grease, gear oil and brake fluid then Mother's billet polish was used on the fronts. I've found the best way to do this job is to get a nitrile glove, dip a finger in the polish and work the polish onto the rim with the glove. This lets you control the amount of polish (little goes a LONG way) and also makes it easier to work the polish into all of the nooks and crannies.
I then take a Mother's Polish cone on an electric drill and work the polish back off the rim. This works pretty good to get the majority of the spots and blemishes off on the first go around. Usually still have some spots left though and I take my glove and work polish back into the areas missed. This makes it a bit easier to watch the spots work out as you work the polish in. I finish it off with a microfiber towel polishing all of the nooks and crannies.
Here's one of the rear rims polished out...
And here is one of the new rims to compare it too...
I realized that my cell phone takes terrible pictures of shiny billet aluminum...but it was snowing too damn hard to go back into the house to get the good camera so this is all we have for now.
I even did the back sides of all of the rims too...
Mother's billet polish applied
and taken back off...
The next step is a sealant to help keep them nice looking under daily driving duties and after races. I've ordered some of this stuff up and will be applying it to all 6 rims later this week.
http://www.shineseal.com/products.htm
It used to be called Zoop Seal but they have reformulated it and now call it Shine seal. It works a bit like Sharkhide, another aluminum sealant that I have used to seal the pontoons on my boat. It seals the porous aluminum surfaces and puts a protective coating on it to keep the aluminum from oxidizing, makes brake dust just blow off and resists water spots making clean up super easy.
There is a cleaner, sealer, slick finish and bright shine metal polish in the kit. They say the sealer goes on kind of like rain-X. Bit like a solvent applied best with a new cloth diaper, let it haze up...then buff it off with a microfiber towel. Once the metal polish is used, the aluminum is supposed to shine as good as if not better than freshly polished billet with no sealant on it. We'll see...
I can't drive it regularly with them the way they were though...this I know. Hopefully this relieves some of the hassle involved with daily driving billet rims. If this doesn't work...they are getting plasti-dipped...
Lance
Old 02-04-2014, 01:54 PM
SHARK HIDE!
It's what the commercial truckers (and I) use on aluminum....
Very expensive - but works
http://www.sharkhide.com
Old 02-04-2014, 03:08 PM
SSLance's Avatar
Sharkhide protects great, the pontoons on my boat look just like they did three years ago when I applied it, I was just a bit concerned about how it would dull the finish of the finely polished billet aluminum.
The Shine Seal is supposed to not affect the shine at all. We'll see. I still have just a bit of Sharkhide left over...maybe a test is justified?
One wheel with Sharkhide and one with Shine Seal...
Lance
Old 02-04-2014, 04:50 PM
Well the wheels look fantastic! And that's a lot of work I know...
Yeah --- you wouldn't want them to dull out at all... and now that you have them spiffed up -- doesn't take as much to keep them that way.
Old 02-09-2014, 11:41 AM
SSLance's Avatar
I got the ShineSeal kit in, I ordered the Master Kit which is says is good for 80 sq ft. Here it is along with the diapers I'll use for applying the sealer and the microfiber towels for polishing.
The bottle on the left is their Bio Cleaner which I mixed 1 oz with 16 oz of water in the spray bottle. This is used to clean the metal surface of any contaminants before the sealer is applied.
The Metal Sealer is the bottle second from the left, this acts and works very much like Sharkhide. It's the sealer that gets rock hard and protects the aluminum from anything penetrating it. The third bottle from the left is the Slick Finish, this may be what separates this kit from the other aluminum finishes on the market. It goes on like a wax but you don't let it dry on the surface you just keep polishing on it until it is all taken back off of the metal. It's the cat's meow... The 4th bottle from the left is a Brite Shine Metal polish that you use should you ever need to clean the Metal Sealer back off of the aluminum. I guess if you ever wanted to polish a shine back onto the surface you'd clean the sealer off with this, then polish, then reapply.
I cleaned the outsides and the insides of all 6 wheels with the Bio Cleaner and a microfiber towel. This wasn't a big deal in my case because I had just polished all of these wheels with Mother's Billet polish so they were already what I'd call very clean but the directions said to so I did.
I then used a diaper to apply the sealer to the outsides of all 6 wheels. It goes on kind of like Rain-X, is very solvent smelling, and is tacky and kind of hard to tell if you are getting an even coat on, especially in all of the nooks and crannies most wheels have. I'd much recommend anyone that is doing this project to have the wheels off of the car laying flat and everything that can be taken out of the way (center caps etc) off the wheels as well. Once I was fairly sure that all of the outside surfaces had a good coat on them, I flipped the wheels over and coated the hoops on the inside. I didn't spend the time or materials to do the back sides of the spokes as they'll never be seen. Then it had to dry and set up. I ended up letting them set for about 24 hours. You can tell if it's not set up by running your finger on the surface, if it smears...it still needs more time.
After BioClean, before Sealer
Same wheel after Sealer applied but not dry yet.
Brand new wheel before Sealer
Same wheel after sealer
All 6 caps...can you tell which two are brand new?
This morning I went out to see if the sealer was dry, and it was...so I set about applying the Slick Finish. Before the Slick finish, the surfaces were kind of tacky...well not tacky but your finger still stuck to it just a bit as you drug it across. The Slick Finish goes on pretty easy and you just apply it and polish it back off working in small areas as you go along. It turns that somewhat sticky surface into a smooth as glass almost Chrome like finish. It is unbelievable... It also lets you polish smooth the top layer of the sealer if there were any areas where you got the sealer a bit too thick. Those areas showed up after the first coat of slick finish is applied and polished out and you just go back over them with a bit more Slick Finish and a clean microfiber and it polishes the surface out super smooth. This is the step that really finishes off this process nice and I believe it HAS to make the surfaces of the wheels MUCH easier to maintain nice looking. The highly polished areas of the wheels feel just like a chrome surface now.
After I was certain the outsides of all of the wheels were as polished as I could get them I flipped them over and applied the slick finish to the insides of the hoops as well. Probably over kill and unnecessary but remember my goal is to get these wheels as maintenance free as I could get them and that includes keeping the insides of the hoops as nice looking as they can be kept as well.
Here is a close up of a used wheel done...Sorry, it's taken with my phone but again, it'll have to do for now.
The camera makes it looks more scratched than it is...to the eye they look pretty dern good.
Here is a new wheel all done...
As you can see it looks great. I wouldn't hesitate to put this treatment on any brand new aluminum wheel...in fact, I'd recommend that you do apply it to your new wheels as soon as you can. The product does nothing to the shine of a billet wheel except protect it and keep it great looking much easier.
I did the insides and outsides of (2) 17x8s and (4) 17x9.5s and this is what I've got left of the kit.
Plenty of Bio Cleaner left over which they say you can also use to clean the wheels with now to maintain them, probably enough Metal Sealer to do the outsides of the wheels one more time, the Slick finish it's hard to see but there is still lots of it left also, I barely used any out of the bottle and never even opened the Brite Shine Metal polish.
And here's the instructions that came with the kit.
Later on after I've driven with the wheels and got them dirty a few times I'll revisit and update with how they have held up. I think it's gonna be good though, it HAS to be better than maintaining just the bare billet aluminum.
Lance
Old 02-09-2014, 01:40 PM
Wow what a difference the front end upgraded poly bushings made.
The wheels look great, you did a nice job on them.
