Old 01-13-2015, 06:36 AM
UMI Performance UMI Performance is offline
Thumbs up UMI's 1972 Pontiac LeMans- Pro-Touring Project- Lots of Pics!
Hello All,
This is UMI's 1972 Pontiac LeMans project. We actually began this project in January of 2013 but since we are new sponsors here at Lateral G we haven't posted anything about it.
I will post a few recap pictures of what has happened in the last two years working on this project. If you would like the full details please visit one of the links below, it would be impossible to repost all those pictures! In the other links there are hundreds of pictures. I also posted our Facebook page link to the album. We will now keep this thread updated from here on out.
Link to Build on Chevelles.com
Link to Build on Pro-Touring.com
Link to build on Facebook
Here is a recap, beginning in January 2013. Us at UMI have and will be doing all the chassis, engine, drivetrain and electrical work. The body work is done by our good friend Buck Struble that does this on the side in his local shop.
As the car started and some of the dismantle:
Old 01-13-2015, 06:40 AM
Skipping ahead to some of the chassis fabrication and painting as well as the completed boxed and powder coated frame.
Our biggest regret right now is no mini-tubing the car.
Old 01-13-2015, 06:41 AM
The last few of the recap. LS1/T56 and pretty much how the car is sitting right now as we finish it.
Old 01-13-2015, 07:09 AM
A few goodies came in.
The Magnuson Supercharger will be a great addition to our LS engine. David over at Magnuson got us the 2004 GTO LS1 kit for this car. Everything works great with the exception of a few small things we need to modify (since this isn't a GTO). The kit looks awesome, well put together and super high quality. Very impressed. More details as we install will come.
http://www.magnacharger.com/
The blower pulleys in the rear are very very close to the firewall and almost rub. The UMI LSX motor mounts P/N 4008 have the ability to move the engine forward to get the clearance we need. However the factory LS1 pan will now hit the crossmember, and since the frame is already powder coated cutting the crossmember isn't an option. So we elected to get the Holley P/N 302-2 pan that offers around 1-7/8" more clearance over the factory LS1 pan. This worked great and gave us the clearance we needed,.
UMI's LSx motor mounts, P/N 4008 that were designed off of this build.
The clutch kit and hydraulic conversion kit with peddle came in as well. We will be using the McLeod RST twin disc clutch with aluminum flywheel.
Old 01-13-2015, 07:36 AM
Nice color choice on the car. Thanks for posting the pictures.
Old 01-13-2015, 01:15 PM
Nice work the paint looks slick! The mounts look nice.
Old 07-03-2015, 01:29 PM
Hoodshaker Hoodshaker is offline
I'm guessing you used the 1434004 McLeod Hydraulic Direct Fit kit which lists out for 1963-1972 Chevelle. I'm looking at this kit for my '71 LeMans GT-37. Was it a direct bolt in or did it require some massaging for the Pontiac?
Old 07-03-2015, 02:22 PM
UMI Tech's Avatar
UMI Tech UMI Tech is offline
It took a ton of work to get the pedal right. We had to modify the main mount on the firewall and also the pedal and pedal hanger. It most likely was designed directly for Chevelle?...
