Big Ford End - "Bolt-On" C6/7 Hybrid Floater
Prev
Next
1
03-19-2015, 09:21 PM
MillerBuilt
Full Floater System -
Installs onto
any
Rear-End that utilizes "
Early
or
New Style/Torino
" Big Bearing Ford Ends.
That's right,,,,
you can use your current rear-end housing
NO welding & simple installation
BOLT-ON
Advantages:
Bolts to your Early OR New Style/Torino Big Ford Housing End
(Chevy 10/12 bolt application now available!
https://lateral-g.net/forums/showthread.php4?t=52854
Reduces/eliminates brake “knockback”
Eliminates axle deflection
Wheel & tire remains intact should an axle failure occur
Front or Rear Caliper / E-Brake Cable Positions
Utilizes the robust, zero maintenance C6/C7 ZO6 Hub Bearing Unit
Utilizes OEM C5/C6/C7 Corvette, and 5th/6th Gen Camaro brake kits
Utilizes aftermarket C5/C6/C7 Corvette, and 5th/6th Gen Camaro brake kits
Utilizes your existing BAER / WILWOOD caliper & rotor (some restrictions apply)
Super compact design compared to traditional style full floaters
All advantages of a traditional style full floater without the maintenance
Replacement parts available at local GM dealer or local parts house
No modifications required to the hub bearing unit as other kits in the marketplace
Note: this applications will add 3/16″ per side to your existing wheel mount surface (based on an existing 2.50″ axle/brake offset)
Fitment: Any rear-end housings that utilizes Early or New Style/Torino Ends
Big Ford
Bolt-On
“Full Floater Kit”
(pictured below)
E-brake Assemblies & E-brake Cable Brackets
NOW INCLUDED
With Each Floater Kit
Full Floater Kit Includes:
• (2) Billet Steel Floater Adaptors
• (2) Billet Aluminum Caliper Brackets
• (2) SKF 33 Spline Hub Assemblies
• (2) E-brake Assemblies
• (2) E-brake Cable Brackets
• (1) Install Kit
• (2) Billet Aluminum Hub Cap Seals
________________________________________
PRICING AT -
https://millerbuiltusa.com/big-ford-base-kit/
Have interest?
Have questions?
Need more info?
Distributor Inquires Welcome!
Big Ford "Bolt-On" kit in action!
09:29 AM
. Reason: Price Increase
MillerBuilt
Find all posts by MillerBuilt
Switch to Linear Mode
Threaded Mode
09:56 PM
