So, I installed the Lokar kit for a column shift. All went as planned, plenty of clearance and got the selector dialed in at the transmission where the range of travel is correct. If you move it too far back the stroke is too short on the column selector, too far forward and the stroke is too long and won't let you select all the gears. About in the middle is just right...
I did notch the frame support to clear the bolt, but don't think it was needed since I set the engine forward 1". Clears the headers, gets all gears and feels factory...
Next up was the compressor install. I used the Alan grove bracket for a Corvette. Part number 144R A.C. They say it may not work for the LSA, but it does........
A few items of note....
I did move the engine forward as I have said numerous times, probably solely for this reason. The engine frame stand needs to have a hole drilled in it to keep one of the rear compressor bolts from hitting. I used a Sanden 508 compressor, but I understand that the Sanden 708 is almost .25" shorter, so it "might" not hit. I have decided to switch to the Sanden SD7 as it is shorter all the way around. The compressor front ear to pulley distance is less than 1/4" difference, so belt alignment won't be an issue.
Also, I will rework the bracket to allow access to the compressor fittings, as the current configuration won't let that happen. In addition, the #8 fitting on the compressor is very close. Vintage Air makes a "tight fit" fitting, but it might not clear. Too many "might's" for me, so I am switching compressors. Having said all that, the reason it worked on past builds is the accessories were f-body style which is over an inch forward of the Corvette/ CTS accessories drives...
If you will notice in the picture, the supplied tensioner clears the CBR rack just fine...
That is all for now.
T,
