Old 09-09-2016, 07:26 AM
Evan Iroc-Z Evan Iroc-Z is offline
I love the torque arm/Watts link setup! You are building a great car that I would love to have. Keep up the great work!
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 09-09-2016, 09:33 AM
BMR Sales's Avatar
Thanks!
Old 10-11-2016, 06:39 PM
TheRealTC's Avatar
TheRealTC TheRealTC is offline
Driveshaft in & it is a beauty - Thanks ShaftMasters!
Old 10-12-2016, 07:42 AM
It'll be a car in no time T.C. !!
Old 10-12-2016, 09:14 AM
BMR Sales's Avatar
Thanks Buddy!
I moved it to my best friends shop in Sarasota this morning so we can do the Electronics, Exhaust ext
Old 10-12-2016, 03:07 PM
It all looks great under there, Nice work.
Old 11-15-2016, 10:55 AM
BMR Sales's Avatar
Subframe Connectors are in - trying to work the exhaust out
Old 11-15-2016, 02:54 PM
Zoomin Zoomin is offline
I really like that you guys are involved in doing work other than exhaust - that way you can see if a change will make another aspect easier.
1964 Lemans
1966 Skylark
1969 Camaro
Old 12-13-2016, 08:06 AM
BMR Sales's Avatar
The Mufflers I wanted were on back-order ( happens to all companies) and I will finally have them Thursday!
Old 01-16-2017, 09:16 AM
BMR Sales's Avatar
Originally Posted by BMR Sales View Post
Thanks Buddy!
With the Shop in Sarasota (an Hour away), it hinders getting some work getting done. Then over Thanksgiving weekend, I broke my Left Hand. Then 10 days later, my friend cut 2 fingers off his left hand! Then he moved to a bigger shop, which at this point is in disarray.
But The SubFrame Connectors are in
