Old 01-19-2017, 10:40 PM
FETorino's Avatar
FETorino FETorino is offline
Appears to have just the right amount of pro-touring going on there!
As in none, yes it does.
Rob in SoCal
Old 01-23-2017, 07:35 PM
DBasher's Avatar
DBasher DBasher is offline
Air in, air out. Check.
Dash and wiring fixed. Check.
Big ole honkin wing on the back. Check.
Front splitter, bolt on deal?
I know your seat time is limited in this car, have you ran with and without wing and splitter? Curious to see if times or even seat of the pants feel is any different.
Old 01-25-2017, 01:00 AM
FETorino's Avatar
The splitter has a simple square tube frame that slides into a pair of small reciever pockets welded to the crossmember. The front is supported by two small turnbuckles attached to the bumper core support.
I have limited seat time period.
The car had the wing and splitter when I bought it so I have never run without them.
I added the larger end plates after I blew the first motor (2 Outings to Streets).
I ran the car at Buttonwillow and once at streets and the second motor let go. It was during that rebuild that I sorted all the other issues out and built the radiator duct and added the hood vents. I also added the traqmate data aquisition at that time so I only have data since then. I changed so many things at once I would be guessing to say what does or doesn't make a difference.
Although I have not been able to really test the wing or splitters effectiveness yet in the future I will use some data to try and tune it. The rules do allow me to run a larger splitter and I have a set of canards for the car. Once I feel consistant in the car at a track and have some data I will try a larger splitter, the canards and possibly run the car without the front splitter to weigh the advantage of grip vs drag.
Big hole in the firewall patched with expansion foam?
Check
That is another story.
Rob in SoCal
Old 01-25-2017, 11:29 AM
There's some leftover sheetmetal in my garage. Would you like to borrow some for that?
Old 01-25-2017, 08:17 PM
FETorino's Avatar
It started out worse
I cleaned it up and tacked a backing plate in place and then made a quick 10 ga plate that I may attach a strut brace to in the future.
Lots of attentiion to detail on the firewall paint after welding up all the uneeded holes
Rob in SoCal
Old 02-02-2017, 06:25 PM
DBasher's Avatar
RACECAR!!
Old 05-14-2017, 03:32 PM
Ron in SoCal's Avatar
Originally Posted by FETorino View Post
Just set some clear attainable goals and get after it.
Priceless !!!
Ron in SoCal
69 Camaro in progress
Old 05-14-2017, 06:31 PM
DBasher's Avatar
Only a few more days....have fun, go fast!
And, don't suck!
Old 05-14-2017, 10:38 PM
FETorino's Avatar
. Will do, I'm hunting Orange Camaros and Yellow Mustangs this week.
And, don't suck!
Never.
Rob in SoCal
Old 05-23-2017, 03:13 PM
Flash68's Avatar
Flash68 Flash68 is offline
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
