Old 08-20-2023, 10:43 AM
Steve68 Steve68 is offline
10lbs in the 1/2 bag,
Those are tight cars,
Old 08-23-2023, 04:05 PM
ProTouring442's Avatar
Originally Posted by dhutton View Post
No fan shroud and only one fan? I hope it’s something that pulls a lot of air. Honestly I don’t see that being an effective cooling strategy.
Don
Yeah, those little fans don't pull that much. I agree wholeheartedly.
Old 08-24-2023, 04:05 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Don
I didn't have any room to do anything else ........The Holley power steering pump sticks out 2.5" and took away any room left for dual fans..... I know that could be a problem ...The fan that I put in is a 16" fan...the car is going to the exhaust shop next Monday and after that I will be able to drive the car and see what the next issues are......A shroud will definitely be in the future......Got my fingers crossed....
Ken
Old 08-25-2023, 04:03 PM
kwhizz's Avatar
Good and another minor issue today.......Again, the car is going to the exhaust shop on Monday....I put another 5 gallons of 93 Octane in the tank and started the car and let it idle for about a 1/2 hour....Temp went up to 195 and the 16" Spal fan kicked on.....The temp came right down to 185 and stayed there.....I'll have to check the fan settings on the Dakota Digital Fan controller......But the car didn't get hot......Good thing....But....The alternator worked perfectly on the initial start-up......But now it won't charge......The Alternator body is grounded correctly so I now have something to occupy my time tomorrow.... LOL....Always something !!!!!
Ken
The Following 4 Users Say Thank You to kwhizz For This Useful Post:
camcojb (08-25-2023), Ketzer (08-26-2023), NAPA 68 (08-26-2023), syborg tt (09-01-2023)
  #45
Old 09-01-2023, 10:33 AM
syborg tt's Avatar
Ken
Ken where you able to figure this out ??
marty-mj
Old 09-02-2023, 04:11 AM
kwhizz's Avatar
The Holley alternator comes with a single wire harness..... After failing to get it to work I called Holley and they think the harness (that has a resistor wire in it to bring the voltage down to 7.8 volts) is bad.......a new one is on it's way....Hopefully that will solve the problem....
The Following User Says Thank You to kwhizz For This Useful Post:
camcojb (09-02-2023)
  #47
Old 09-03-2023, 05:54 AM
kwhizz's Avatar
A little more to the story .........Last week when I took the car out for a ride to check out the cooling system and any other problems that might pop up....Remember that the Alternator wasn't working so I had the battery fully charged and I wasn't going very far...So, after driving the car a couple of miles in traffic everything was good except for the Alternator, as I was heading home all of a sudden the check engine light came on.... Now what.....I was almost home so I pulled the car in the garage and shut it off....I went back after about a 1/2 hour and started it up to see what was going on..... The check engine light was still on and the Volt meter was just above 10 volts and as I looked at the oil pressure gauge in the Dakota Digital display the oil pressure dropped to zero.....I shut it off and was freaking out.....A couple minutes later I started it again and the gauge showed "0" oil pressure.... At that point I had it and went in and didn't want anything to do with cars....Because it was a brand new engine under Warranty I called the GM tech line the next day and I was told to take the car to a local dealership and they might decide to get involved.....but because it was a old car they had no obligation to get involved.....I could see where this was going.....So, that night I was thinking about how do I figure out exactly what was going on.....So I went out and bought a manual Oil Pressure gauge and hooked it up.....Hit the Key and Boom...60 lbs pressure.....Hummmm!!!......Shut it off and put the Battery charger on....Let it charge to it was full and I disconnected the battery cables.......Hooked them back up again and started the car and the check engine light was off and the oil pressue gauge showed the same pressure as the manual gauge.....Hummm!!!.....Then it dawns on me that the problems all started because of the low voltage situation that happened when I was driving the car.......Thru a fault into the system.....I'm still waiting for the new harness to arrive from Holley to get the Alternator working...... But... we had a big car show in Kenosha and my grandson wanted to drive his car there.......So I fully charged the battery and took my fully charged Battery Jumper and hooked it up to the battery in the trunk of the car....Even though the show was only a couple of miles away he basically now had two batteries supplying power to is car.....It never ends with this car stuff......Here's a picture of the car at the show
The Following 5 Users Say Thank You to kwhizz For This Useful Post:
camcojb (09-03-2023), dhutton (09-03-2023), fleet (09-12-2023), waynieZ (09-16-2023), WSSix (09-07-2023)
  #48
Old 09-03-2023, 08:59 AM
camcojb camcojb is offline
Love that car!
kwhizz (09-03-2023)
  #49
Old 09-12-2023, 01:36 PM
kwhizz's Avatar
Finally got the new harness from Holley......Before I put it in I took the Alternator back to the Alternator shop to be checked out again....when he put it on the test rig and hooked it up with a standard 4 pin plug everything checked out O K except he said the red light didn't come on before he started the test......I asked what red light, he replied that it was the red light in the dash cluster that turns off when the alternator starts charging and if it quits working in a normal dash the light would come on and let you know it wasn't charging.......After thinking about it with my limited knowledge about how these things work I thought that maybe there was a problem with internal regulator in the alternator.......So... When I re-installed the alternator and put in the new harness and it still didn't charge.........I called Holley and asked if I could order a new regulator just to see if that was the issue......I was told they don't sell replacement parts......So.... I ordered a new Alternator.....Should be here tomorrow...Just want the problem to go away as I am sick of this simple problem that is so complicated..Got my fingers crossed
The Following 3 Users Say Thank You to kwhizz For This Useful Post:
camcojb (09-12-2023), syborg tt (09-20-2023), waynieZ (09-16-2023)
  #50
Old 09-12-2023, 03:17 PM
ScotI ScotI is offline
Is the Holley stuff proprietary & not GM late model based so you could use a local parts store alternator or regulator?
