Old 02-16-2013, 06:05 AM
Sieg's Avatar
Sieg Sieg is offline
Plan your work and work your plan.
Speaking of plan.......have you considered using a Year-at-a-Glance planner instead of a Decade-at-a-Glance?
Old 03-17-2013, 07:58 PM
Track Junky's Avatar
With the May Thunderhill event coming up and realizing that driving two hours to Vince's shop to work on my motor wasn't going to happen I drove down to the shop last week and picked up my motor and all the parts and pieces to put her back together.
I mentioned that I would never go back to a timing chain after breaking one at T-Hill last May so I picked up an Xceldyne belt drive. It was the first time for me ever installing a belt drive but the directions were well written and the quality of the parts and pieces were top knotch.
Got the belt drive installed and heads torqued down this weekend.
Gaetano Cosentino
Old 03-17-2013, 08:01 PM
Sieg's Avatar
Nice bottom end!
Old 03-17-2013, 09:17 PM
Cole Cole is offline
Banned
Nice bottom end!
That doesn't sound very proper....
Old 03-17-2013, 09:56 PM
intocarss's Avatar
You're looking real racy now
Old 03-18-2013, 05:40 PM
Nice bottom end!
Nice, not very proper, and racy........I can live with that. Kind of like how I liked my women..........well, back in the day anyways.
Anyhow, In my efforts to try and get the rear of my car to rotate I asked Vince to make a slider clamp for my rear Hotchkis sway bar so that I can make it adjustable. Vince has sent a computer drafted design of the sliders to the water jet guy. He sent me an e-mail of the design and if I can figure out how to post from e-mail I will. Basically just a block of billet aluminum with a hole in it the same diameter of the bar that will wrap around the sway bar with two bolts on the bottom to sinch it to the bar and a heim joint connection on top. Hard to believe I couldn't just find one on line. BMW has a custom sway bar set up with the sliders but they wouldn't seperate the sliders and heim joint set up from the bar. Should be pretty neat and I'm looking forward to putting it to work.
Gaetano Cosentino
Old 03-18-2013, 10:03 PM
Flash68's Avatar
Flash68 Flash68 is offline
Cool on the belt! Who needs a stinkin gear?
Forward me the email and I will post it up.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 03-19-2013, 02:45 PM
Beach Cruiser's Avatar
Beach Cruiser Beach Cruiser is offline
I checked out the local shop that was running Camaros and BMWS in the Contential tire series not to long ago. They had the coolest set up for in car adjustable sway bars. Basically the swaybar arms are square, but more like flatbar stock. They have a system to rotate the arm from the drivers seat so that if they stand the arm up complety vertical its the stiffest, and if it's rotated flat (180 degs) its at its softest. So, the arm not the bar is adjusted for the stiffness, all from the drivers seat!
No Shop, No Money, No Time.... No problem!
Old 03-20-2013, 07:50 AM
chetly chetly is offline
are you talking about a blade, something like this?
http://ankenyracingenterprises.com/i...ybar%20002.JPG
Old 03-20-2013, 08:29 AM
Basically will look like this.
The slider clamp will allow me to slide up and down the sway bar arm. The shorter the arm, the stiffer the setting. The clamp Vince is making wont be a two piece though, will be thicker, and have the two sinch bolts lined up horizontally at the bottom.
Gaetano Cosentino
