Old 01-19-2025, 09:10 AM
camcojb camcojb is online now
Thanks for the info Mark. I plan on getting one for the Chevelle.
Old 01-25-2025, 09:10 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Mark can you please share the part number for the upper radiator hose. I have recently installed the Holley Mid Mount and the Acdelco 22842M hose is a bit short.
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 01-26-2025, 05:05 PM
AJG87 AJG87 is offline
I believe Mark posted this already; D71267 upper hose.
The Following 2 Users Say Thank You to AJG87 For This Useful Post:
camcojb (01-26-2025), Ketzer (03-30-2025)
  #494
Old 01-27-2025, 09:41 AM
Stielow's Avatar
Stielow Stielow is offline
Thanks, I have not had a chance to look it up.
Mark
Stielow Engineering
The Following User Says Thank You to Stielow For This Useful Post:
camcojb (01-27-2025)
  #495
Old 01-27-2025, 10:36 AM
72Z/28's Avatar
Thanks a lot man. I do not know how I missed it. Just placed an order from Rockauto, and hopefully it fits perfectly.
72 Camaro RS:SOLD
68 Camaro:
The Following 2 Users Say Thank You to 72Z/28 For This Useful Post:
AJG87 (01-27-2025), camcojb (01-27-2025)
  #496
Old 02-20-2025, 08:33 PM
mdavidthomas mdavidthomas is offline
Someone earlier in the thread asked about the fuel tank vent system. You replied that you would show it once you had it worked out. Do you have a solution for this now on the Hobbs Camaro?
Also, wondering what the bore size of the 2002 F-Body clutch master cylinder is that you are using on your builds?
Thanks,
mdavidthomas
Old 03-29-2025, 03:08 PM
Stielow's Avatar
I finally got the Camaro on the road. Like most of these projects… it had gear whine.
I tried a 12 bolt this go around because that was original to the car.
The only gear I could find at the time was a repo 12 bolt gear. I think is it was a Strange.
I’m looking for a real GM 12 bolt gear. Prefer 3.73 but a 3.55 will be good also.
I’m putting out the I need help beacon on Lat-G and maybe someone has one or knows where one is.
Other than that the car runs great!!
Stielow Engineering
camcojb (03-29-2025)
  #498
Old 03-29-2025, 04:54 PM
https://www.yenko.net/forum/showthread.php?t=181631
Old 03-29-2025, 04:56 PM
If you could live with 3.31
https://www.yenko.net/forum/showthread.php?t=181383
Old 03-29-2025, 06:37 PM
Stielow's Avatar
Thanks Jody!!
Stielow Engineering
