Old 07-06-2013, 12:47 PM
Just a thought on the white one, could you switch it to run E85? That might be something to think about. I only know E85 is a higher octane fuel though so I could be sending you on a goose chase.
Glad to see you're having fun and making progress. Novas need more attention.
Old 07-06-2013, 01:41 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
nice collection of novas,I am a nova fan also
Old 07-06-2013, 04:16 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Originally Posted by andrew5 View Post
it has mufflers and all the light work! but that c12 is not cheap.it is a little radical for my small town streets as well.it's on the back burner for now.i need to get crackin on my red nova.
My 68.
Mine is 11.5 to 1 with a 600 lift roller so I can get by with 110 and some pump gas, but I agree, still expensive to burn...
Can't wait to see more pics of the Red car!! Get crackin'!!
Jeff-
Old 07-06-2013, 07:50 PM
andrew5's Avatar
andrew5 andrew5 is offline
will do! and nice car!
Old 03-02-2014, 02:48 PM
andrew5's Avatar
got the hydroboost,power steering plumbed,cooling system,all c5 brakes installed and lines run.put in "c' clip eliminators and HD strange axles with 1/2 inch studs.had driveshaft made,3 inch stainless magnaflow exhaust.i wired in the battery in trunk with ford starter relay.wired in ignition switch,fuel lines.tci shifter. inner fenders.getting there. i should be on the road by summer. probly late summer!
Old 03-07-2014, 05:50 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
looking great! did u have any problems installing the steering shaft with the AFR's moving the headers up a bit?
WicKeD
Old 03-13-2014, 07:06 PM
andrew5's Avatar
yes! i was a little tricky.took quite a few hours,but steers like butter.i used a stock gm column.i will post some pics this weekend.
Old 03-14-2014, 07:11 AM
Ketzer's Avatar
Sure is turning out nice! Beautiful car!!
Jeff-
Old 03-14-2014, 08:35 AM
mexMan's Avatar
mexMan mexMan is offline
What wheels are those?
''Every car has a great quality, is not the hands that build it, is the dedication behind it.''
Old 03-14-2014, 09:06 AM
ScotI ScotI is offline
Nice collection of Novas. This car has a sweet parts list & the white/blk vinyl top car looks OE great!
What accessory bracket set are you using on your 427? Looks like 88-93 GM sbc serp brackets.
