Old 02-07-2014, 10:06 AM
glr0212 glr0212 is offline
I think it is important! Giving a base track width or some other reference dimension will help people tremendously. I was a bit surprised to see the ridetech president say without qualification that you have to have a 5.75" BS.
Maybe since RodP has a setup on a stand he can give us that reference dimension.
Originally Posted by gray776 View Post
Great write ups Rod! I agree that you should always measure for yourself especially with the differences in brake kits. Could you take one more measurement for me? It would be nice to have a reference with Ridetech's setup as installed, for dimension or track width to the rotor. Say from the frame to WMS, or spindle to WMS? Does that make sense? Then the rest of us could adjust by comparing that against our own brake systems to determine if our actual BS measurements seem correct.
Its probably not that important, given that we should measure ourselves, but thought it might help someone.
Thanks,
Jason
Old 02-07-2014, 10:14 AM
Damn True's Avatar
Damn True Damn True is offline
Thanks,
Jason
It seems to me that the critical measurement is WMS/WMS. I'd assumed that any size recommendations given by RT were based on using a duplicate of their setup. Change anything that impacts WMS/WMS (CA's, rotor hats, hubs) and those recommendations go out the window.
....and given the frequency with which there are variations between cars, even from the same year and same plant it seems incumbent on the buyer to do a lot of measuring before purchasing wheels & tires.
Old 02-07-2014, 10:57 AM
rchaskin's Avatar
rchaskin rchaskin is offline
every car is different...I still say its all in the alignment..btw....18x10 6 7/8" back space 285/30/18 23.5" fender height -.8 camber 5.6 degrees on caster on a 71 Nova.
Modifications, button head fender well bolts and tru turn. Steering components are 1/8" away from wheel hoop inner step. Fully cleared on a smooth hoop.
Ok, whats up with the bump stops guys.
Uh.....this looks awesome.
Randy
1971 Nova
https://www.youtube.com/user/rchaskin/videos
Old 02-07-2014, 12:36 PM
Rod P's Avatar
Rod P Rod P is offline
Originally Posted by glr0212 View Post
First off, thanks for the pictures and write up!
I see the car you used is a little higher than mine. Maybe I should bump mine up and realign it and see where i am at.
Here is my main question to you, and still some of the heartache I have with this setup. How do you drive a car with this setup when the fender is sitting on the wheel during a turn?? If the fender moves down at all its going right into the tire and rubbing like a mofo. (ie turning into a raised parking lot or making a high speed turn)
the wheel negative cambers inward away from the fender that's part of the reason for the tall spindle...to help the camber curve, but you should roll the inner fender, I know it looks like it should hit.....but the wheel does camber inward, on my car I cant get a pencil between the fender and tire and with the camber movement it doesn't hit, even on extreme movement
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 02-07-2014, 12:40 PM
Rod P's Avatar
Thanks,
Jason
agreed Jason I will take the extra measurements, I will remove the coilovers to get you guys the measurements at full drop, ride height, and full compression, I will try monday or tuesday, in between projects
Rod Prouty
Bangshift Stories
Old 02-07-2014, 08:53 PM
cwylie cwylie is offline
Originally Posted by Rod P View Post
on a addendum note, so after looking over different installs, my recommendation to EVERYONE is to measure your own car for its back spacing the one biggest factor I found in the installs is the brake packages that are used I found the some CPP brake kits with hubs pushes out the wheel mounting surface just over a 1/4 inch, and the some willwood kits push the mounting surface out almost a 1/2 inch, so unless you know that (you measured) the wheel mounting surface is still in the original location or you are using the very same Baer Brake package we used the 5.75 suggestion would be off by 1/2 inch, also please use the alignment settings given, make sure the sheet metal on your car is aligned, have good body bushings, the tru-turn kit pushes the tire width limit of a stock frame to max performance, so the rest of the assembly needs to be of the same caliber
So the wilwood kit is narrower or wider than the baer?
Old 02-07-2014, 10:29 PM
Vince@Meanstreets's Avatar
The Wilwood hat that I have is a tick under 5/16" the Baer is under a 1/4". Point is you have to measure and measure again.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 02-09-2014, 02:00 PM
brownz brownz is offline
I also have a nova with tru turn running 18x9.5 wheels with 5.75bs. The onlt issue I have is a slight rub at lock. and this is because I dont have the ride tech arm on my car. I did remove the top inner fender bolts just to be safe.
Old 02-10-2014, 02:44 PM
What brakes are you using?
Old 02-10-2014, 08:54 PM
Hey Rod,
What is the ride height measured to the top of fender on your 68? Is it also 23 3/8"?
