Marty,
What kind of transmission controller is this?
Also, Great pictures!
It is a PCS (Powertrain Control Solutions) push button shifter for the 6L90 trans. I beleive it works with 4L60 and 4L80 transmissions as well as a few others.
Did you use the hardware from the Corvette to make this? I want to streamline my doors, but don't really want to use door poppers and the Corvette hardware is what I was thinking of using.
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
