So heres today's update... The news is mixed.
First the bad news. When I pulled the passenger side head off, this is what I found:
After some head scratching, and then looking at the driver's side head, we realized that the bent valve broke the valve guide (which is powdered metal on the L92 heads from GM), and a piece of that bounced up off the valve, into the plenum, and down into the #2 cylinder. It beat up the top of the piston pretty good, and it's left shrapnel embedded into the head surface. It's fairly rough, but I'm hoping that the head can be milled to smooth out the surface without dropping the chamber size too small for my desired PTV clearance and compression ratio.
Here is the valve and broken guide:
So, onto the better news. After getting past this, and taking Eric to lunch, we loaded the rest of the shortblock into the truck and I ran it over to Texas Speed. I have decided to forego the sleeved block idea (too much time, money, and not enough bang for the buck). We unloaded it there and their head machinist took a look at it. After some discussion, they backed off their previous limit of only taking the bore to 4.010" on this block and say they can go to 4.030" on it. BUT, it's still not clear whether that will be enough to clean this up or not.
The plan at this point is for them to disassemble the short block, check all of the cylinders to see if there is any more damage (thankfully the walls on #2 don't look to be damaged, just the piston and head), and get back with me. I expect to hear from them by Wednesday. If the block is salvageable, we are going to bore it, get a new set of pistons, and put it back together. If not, I'm getting an LS3 block, boring to 4.070" and running it as a 418ci .
Now, the other thing I did today was spend an hour and a half on the phone with Brian Tooley of Brian Tooley Racing. He's been doing LS work for almost as long as the LS has been around. He originally founded TEA, which he sold to Summit Racing (didn't know that) in 2004, and he now does parts sales and cam work. I've known of him for a long time, but in my recent research, I learned that he's been spending a good bit of time learning about what works and what doesn't with the single plane intakes for the LS engines.
During our long phone call, we discussed my current cam and performance level, my current heads and alternative options, and what I would like to end up with after all of this. It turns out that he recently did a big dyno study of the effects of valve timing on performance in the LS engines with the single plane Victor Jr. (my intake) and the L92 heads (my heads) out of the box (mine have had some work done). So he had some great data to share.
We have ended up on a plan that involves me sending my heads to TEA for the repairs, then to him for some touch up work in the ports and chambers, and then back to me with his valve springs installed. He is also going to spec out a custom cam grind for me, one which allows me to run more compression (~ 11.5 to 11.75:1) and will help my midrange powerband. I'm really excited about this step!
Today was a long day of research and phone calls, then running to Eric's to tear the engine apart, running it over to TSP, then packaging up the heads to get them on the way to TEA. I had to get it all done today as I leave town tomorrow for a week... I'm still pushing to get it all back together by March 1st, which will give me 2 weeks to break it in and tune it before the Fort Worth GG and USCA the weekend after. The long pole will be the heads. I'm going to lose 2 weeks just to shipping on them. But I think the results will be worth it!
I gotta go pack now! Early flight tomorrow... More news as it trickles in from TEA and TSP.
