Old 11-29-2015, 09:27 AM
TomM's Avatar
TomM TomM is offline
Updates.....
Got the harness installed from BP Automotive....also Corvette gas pedal....
Reworked the brake lines. Mounted the Rick's Vaporworxs tank with the ZL1 fuel module...
Transmission cooler mounted...
Engine grounds and misc. wiring...
Got this neat fitting from Turn1. Solves the power steering issue however, the fitting was for the Toyoda (yes with a D) style pump commonly found on the LS3 Corvette motors. A quick trip on the lathe corrected the issue of the barrel of the fitting being to large, and a hair too long...
Finally, custom drive shaft from All American Drive shaft good to 1K horsepower....
That is all for now....
T,
Old 12-13-2015, 12:00 PM
TomM's Avatar
Default Update...
Got the exhaust all done. Had to cut the tailpipes and re work them, nothing too bad, mostly just re clocking the pipes to clear the 4-link...
Plenty of room over the axle, 4 link bars and brake lines. Nice clearance all the way around...
So with the exhaust done and the underside of the car basically done, I moved to the front.
I have an Entropy dual pass radiator. I also have an inter cooler now, as well as the AC condenser. So I mocked it up and there was no way all three of those items are going to fit into the space. After doing quite a bit of research I landed on replacing the fans.
The existing fans are 3.75" deep. I found some Spal fans of about the same dimensions except 2.50" deep. Took a gamble and purchased two of them...well lo and behold, they work. I am able to move the radiator back, fit the inter cooler and then the condenser. I may have to notch the hood latch a tad, but nowhere near the problem I had before...
Old fans...
New fans installed on radiator...notice the core support gap...
Looks like the hoses will go right through no problem...
Intake elbow clearance good...
Pulley clearance good. If I ever have to replace the idler, the radiator will have to come out...
Will start getting the inter cooler mocked up, pump and fill neck mounted and then start the plumbing......
T,
Old 12-13-2015, 01:42 PM
69x22's Avatar
69x22 69x22 is offline
Looking nice! Everything is tight on a Chevy II.
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
Old 12-14-2015, 04:59 AM
World War Z World War Z is offline
Nice set-up Tom!
I'm running an LSA as well....the torque is life-altering!
Old 12-14-2015, 05:59 AM
TomM's Avatar
Thanks. Yep a 1/4" is a mile on these cars. I should take Ken's lead (KWhizz) and pick a bigger car next time....LOL
Originally Posted by World War Z View Post
Nice set-up Tom!
Thanks, yeah I read your thread on your Camaro....nasty looking beast.....I want one....
T,
Old 12-14-2015, 06:17 AM
Jay Hilliard's Avatar
Great job Tom. I may have missed it, but what 4 link setup did you go with?
Jay
Old 12-14-2015, 07:07 AM
TomM's Avatar
Church Boy's Racing triangulated 4-link....
T,
Old 12-14-2015, 10:12 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Very nice work Tom,tight fit for sure in sure
Old 12-20-2015, 02:39 PM
TomM's Avatar
Default Small update...
Got the inter cooler and the AC condenser mounted. Looks like everything will work fine. I started modifying the hood latch and its support. Not done with that yet ran out of time...
T,
Old 12-27-2015, 02:37 PM
TomM's Avatar
Default Update...
Got the inter cooler all plumbed in, just need to figure out some kind of hose clamps to hold them together....
Also got the power steering cooler mounted and hoses connected. It should get enough air, but not really worried about it. This is more for additional fluid capacity, as the CTS reservoirs are small....
Bumper mounted, plenty of clearance...
T,
