Old 12-15-2015, 06:19 PM
The motor looks nice in there. Plenty of room.
The Following User Says Thank You to waynieZ For This Useful Post:
toulastang (10-15-2018)
  #52
Old 12-17-2015, 04:29 PM
kwhizz's Avatar
kwhizz kwhizz is offline
Things are moving from the waiting for "Stuff" mode to the Get'r Done mode.......... Thanks to Donny Bock at American Autowire I now have the right stuff to upgrade the Nomad......
We are going to replace the "Old" with the "New"
Then........It's kind of hard to see how far out the frame mounts are......I made the Aluminum Jig to the 16.5" centerline as required and the mounts are way out.......I cut them out and will modify them correctly......
Also.....after test fitting the engine in the car.......It became apparent that my plan to mount the A/C compressor down low like I did in the Chevelle just wasn't going to work.......Darn......Mounting the compressor up high on a LSA engine is not that simple.........so.........I decided to bite the Bullet and buy a Concept 1 front drive system.........and with this system I had to remove the front snout assy from the engine so I can send it to Lingenfelter to get a new Hub installed on the Supercharger shaft for the Concept 1 Pulley......
Here we go............
Old 12-17-2015, 04:36 PM
Did I give you back that roll of black you bought somewhere in Texas or Oklahoma??? LOL
You are the man Ken!! So fun watching this..... "Hey! You know what you need.....?"
Old 12-18-2015, 05:06 AM
jy211's Avatar
jy211 jy211 is offline
love seeing posts like these!
Old 12-21-2015, 06:21 PM
ChuckDriver's Avatar
ChuckDriver ChuckDriver is offline
Killer Nomad!
JJ
My 1957 project:
http://67-72chevytrucks.com/vboard/s...d.php?t=334552
Old 12-25-2015, 10:57 AM
kwhizz's Avatar
I finally got the motor mount situation corrected.......Lets just say the old engine fit.......but it wasn't correct....I cut out the mounts and basically raised the mount position 1/4" to give me a little more pan clearance and made the mounts the same height relative to the frame (there was 3/16 difference)........I welded the spacer plate to the cut off mount......used my Jig and bolted the mounts in ......after everything checked out I welded them in......Side story........I have a good 110 volt Miller wire welder and got an education about extension cords......LOL.......I now have a new 12 Gauge wire one in the garage.........."I are Smart" now.........
Cleaned and painted the mounts and put the engine back in.......Fits "Perfect".......Still waiting for the Supercharger "snout" to come back from Lingenfelter with the pulley mod for the Concept 1 Front Drive set-up......So...I started the wiring process with American Autowire Classic update kit ....Here are some pic's
Old 12-25-2015, 12:35 PM
preston preston is offline
In my heavily modified car I have basically zero room for an Hvac unit although i fit a small hot rod heater in there. Sometimes I take out the tape measurer and sigh while I try to determine if some tiny inefficient ac unit could possibly fit.
which is all a long winded way of saying I envy your giant A/C unit !
Sometimes taking a car like this and rebuilding it "the right way" is almost more fun than building from scratch.
Old 12-28-2015, 05:17 PM
kwhizz's Avatar
In retrospect..........I can't even imagine trying to get all the electrical power required for this conversion thru the stock fuse panel.....Thanks to Donny Bock at AAW for pushing me into the rewire....In the mean time I have a good portion of all the wires run ......the mass of wires in earlier pictures are now in place and just need to be zip tied in place after getting the Dakota Digital modules wired and in place........I also have the new A/C unit installed under the dash and everything wired......the Supercharger snout should be coming back from Lingenfelter next week and the new front drive should be showing up also.....I also did some checking on Transmission dimensions and it looks like I have to move the trans mount back 3 1/2" on the frame from where the 700R4 was........Time to move the car's around and get the 57 up on the lift ........
Old 12-30-2015, 08:31 PM
kwhizz's Avatar
A little update......Still waiting for the new Front Drive to show up,...The Supercharger snout is still at Lingenfelter Performance for mod's....and the stock dash gauge housing was sent out for stripping to get the chrome off and ready for paint.....that will be painted and ready for final assy in the Dash next week ....so.....After finishing up the basic wiring under the dash.......the next big wiring issue is getting the Dakota Digital modules in and wired........there are three modules....the main VHX module......the Fan Control module.........and the GPS Speedometer module........Got everything hooked up and decided to take the Speedometer module out of the box and plug it in........ The Voltmeter guy does it again....Got Lucky (so Far) as the basic functions even work........LOL
Old 12-31-2015, 11:01 AM
kwhizz's Avatar
Got a few things buttoned up today.........Got the modern Wonder Bar radio installed.....am/fm stereo, Sirius, Bluetooth........Neet !!!.....Also got some neat Speakers and Tweeters that are matched to the system.....I also got all the OEM converted Heat/ AC controls in and finished all the internal wiring....dash lights are all hooked up also......Time for a Nap!!!
