Old 05-29-2019, 05:14 PM
Nlped47's Avatar
Nlped47 Nlped47 is offline
Default 1963-1/2 Ford Falcon Futura
I’ve gotten side tracked on the ‘shop truck’...aka Belushi
Day it came home..
Some suspension changes..
Interior before...
Now... (it isn’t finished as I’m waiting on a seat cover and some door panel trim)
And, this...
Before:
Now:
Old 05-30-2019, 03:01 PM
Flash68's Avatar
Flash68 Flash68 is offline
Belushi..... Nice!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 05-30-2019, 05:30 PM
Nlped47's Avatar
Belushi..... Nice!
, yeah, I have another blue C10...it’s a ‘68 swb Fleetside named Walter, but this new one is a Blue(‘s) Brother. Had to be it’s name.
Old 06-08-2019, 08:38 PM
Nlped47's Avatar
I got the intake leak on Martha finally fixed!
On another note....
I also needed to post a before and after of Belushi...(after the drop and detailing)
Old 06-17-2019, 05:46 PM
Nlped47's Avatar
Well, I got all the little leaks solved and the Broader Performance AOD took a dump! So, I’m hunting a 4r70w to put in that POS’s place.
Old 10-06-2019, 10:26 AM
Nlped47's Avatar
Haven’t had much time to tinker on the Falcoon for quite some time. Only due to my automotive ADHD. I bought, fixed up & just sold a 1987 R10 Chevy Silverado.
So now I’m getting back to the Falcon. While working on the Chevy, I did get an ‘01 V6 4r70w, had it rebuilt, ordered a PTC 10” convertor and the US Shift Quick 4 controller & harness, and the Lokar shift shaft.
I’ll have to have the aluminum driveshaft shortened 1” related to 7/8” longer transmission housing. I did have to offset the crossmember mounts rearward 1” and ‘modify’ the trans tunnel to clear the larger bellhousing of the 4r70w vs the AOD. I’ve had the trans in & out 3 times to get fitment worked out.
Once the new parts arrive, I’ll get the shift shaft swapped out and in it will go. PTC says 2-3 weeks on the convertor, so I’m going to get to work on the interior work.
Just a gratuitous shot of the Chevy.
The Following User Says Thank You to Nlped47 For This Useful Post:
syborg tt (10-12-2019)
  #57
Old 10-06-2019, 12:20 PM
ScotI ScotI is offline
Not up to date on the blue oval stuff.... Is the 4r70w an updated/improved version of the AOD? Or diff trans altogether?
Old 10-06-2019, 04:25 PM
Nlped47's Avatar
It’s an electronically controlled tranny. Kind of an AOD on steroids. Think, 4L80e vs a 700r4.
Old 10-12-2019, 02:46 PM
Nlped47's Avatar
I got the PTC convertor today. I also received the US Shift Quick 4 controller this week.
But, I’m still waiting on the Lokar shift shaft, so I’m stuck on hold until it gets here. I have to have it so I can get it installed before I’ll be able to install the transmission. I ordered it well before I got the other stuff... AGGRAVATING.
Old 10-12-2019, 05:14 PM
Glad you're still making progress on the Falcon. You did great work on the trucks. I feel you on the automotive ADHD. I have trouble deciding to work on the TA or a BMW I bought. Good luck moving forward with whatever you're working on.
