Old 10-27-2007, 01:22 PM
James OLC's Avatar
Originally Posted by awr68
Looks good! What else needs done before the teardown for body/paint?
Where to start...
  • Mount shocks and remote reservoirs with plumbing
  • Plumb diff cooler with remote pump
  • Fit axles and brakes, plumb brake lines
  • Mock up Toyo R888's, trim quarter as needed and order wheels
  • Run sensors for traction control
  • Plumb fuel and return lines
  • Run battery cable to starter
  • Finish running lines for A/C
  • Cut tunnel for shifter
  • Final fit for oil cooler, trans cooler, and ps cooler
  • and a couple of bits and pieces here and there before blowing it apart
we're hoping to have the underside done and in paint with the interior and roll cage first week in December.
Thanks for reminding me of the list, it's been like twelve hours since I last stressed about it - lol.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 10-27-2007, 04:57 PM
68protouring454's Avatar
traction control uh??? killer
Jake's Rod Shop
Old 10-27-2007, 06:08 PM
James OLC's Avatar
Yep, we're working on integrating an adjustable electronic traction control system with the LS7. Our biggest stumbing block had been the reluctors for the rear wheels. Bret and the guys at Mark Williams were the only guys I found who were interested in pursuing a solution for us.
James
1969 Camaro - Dusty
Old 10-27-2007, 07:50 PM
olds87 olds87 is offline
The car is coming together nicely.
James W.
1987 Oldsmobile
Cutlass Supreme
Old 10-27-2007, 07:51 PM
Sales@Dutchboys's Avatar
WOW!
Paul
dutchboyshotrods.com
269-823-2967
Old 10-28-2007, 04:30 PM
Wow looks awsome the way you tucked it up so tight for clearance.
Old 10-28-2007, 08:45 PM
ohcbird's Avatar
ohcbird ohcbird is offline
Is there still room for the shocks?
Great project man- I love the updates, as they serve as motivation!
Old 10-28-2007, 09:21 PM
BC69's Avatar
BC69 BC69 is offline
Nice! Do you have pictures from the side to see what it looks like on the quarter?
Tim
In memory of those gone before us
In gratitude for those who care.
Old 12-05-2007, 07:10 AM
James OLC's Avatar
Default OneLapCamaro - Engine Update
Well we finally made it to the point where we are starting work on the engine for the OneLapCamaro project. We were fortunate to find nice donor to use as a starting point:
It came out ot an '07 with just 5,000 miles on it. The owner was upgrading to a twin turbo setup.
James
1969 Camaro - Dusty
Old 12-05-2007, 07:11 AM
James OLC's Avatar
A couple of weeks ago out it came:
And now it's over at Katech Engine Development for a complete teardown and rebuild to their Street Attack specifications.
This should be a lot of fun. I'll try to post pictures through the build process.
James
1969 Camaro - Dusty
