Old 01-02-2020, 05:12 AM
Gmachine1911's Avatar
Gmachine1911 Gmachine1911 is offline
Nice work, Shane. You certainly have come a long way. Keep up the good work!
Thanks, Trey, I appreciate it! Can’t wait to see this thing sitting on the ground again. If I’m being honest, I would’ve probably been better off passing on this one, however, there’s great satisfaction in seeing it come back to life again. Besides, not counting the suspension, I still have WAY less then the cost of a new body in it, so I keep telling myself I’m coming out ahead!
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
Old 01-02-2020, 07:17 AM
streetbird's Avatar
streetbird streetbird is offline
I had a harbor freight spot welder to, it tack the panel but I do some strengh tests and the tack was weaks. So I didnt take chance and I didnt use it.
Take 2 sheets metal and do only one spot. Do rotation and you will be suprise how it break easy
The French Frog
Old 01-21-2020, 09:41 PM
So I got what should be the final pieces of replacement metal for the Nova today. I was originally gonna make patch panels for the inner A-pillars and bottom of the front door jamb areas that need replaced, however, I decided to just spring for the entire panels. The car goes to the body shop next week for panel fitment, roof replacement, A-pillar repair, etc. and when I get it back it’ll be a rock solid foundation for the fun part of the build to begin on. It’ll be nice to be adding parts instead of cutting them off!
I also pulled the front end back off and started filling the holes in the firewall.
Shane
#theanchorholds
Old 01-26-2020, 02:38 PM
87SS's Avatar
87SS 87SS is offline
Wow!......Keep up the nice work!
What color is in the plans?
1976 Trans-AM
1987 Monte Carlo SS
1989 MR2
1995 Trans-AM
Old 01-26-2020, 08:53 PM
Thank you! As much I enjoy it, I’m ready for a break, especially when it comes to panel fitment...it’s truly a skill and I’m not blessed to have it!
The color choice is still up in the air but while we were on HRPT we saw Church Boys’ 66 Nova and my better half fell in love with that maroon. I was initially pulling for Silver but lately I’ve been eyeballing white which is surprising since I swore against having a white car after my Camaro was white for so many years. There’s something that keeps drawing me back to the white, though.
Shane
#theanchorholds
Old 01-26-2020, 09:13 PM
bkswede bkswede is offline
You’re making good progress, and it looks great! Keep the updates coming!
Sent from my iPad using Tapatalk
63 Chevy II - Build in Progress
2017 Camaro ZL1
2010 Mercedes C63 AMG
The Following User Says Thank You to bkswede For This Useful Post:
Gmachine1911 (01-27-2020)
  #57
Old 02-28-2020, 05:18 PM
Got some goodies for the Nova today since the body shop needed the tail lights to get the rear sheet metal lined up. I like the clean look of the all-red lens so I opted for the backup light delete.
Shane
#theanchorholds
The Following User Says Thank You to Gmachine1911 For This Useful Post:
waynieZ (02-29-2020)
  #58
Old 02-28-2020, 06:07 PM
They’re making some good progress on the body. Got the doors and quarters lined up and doors latch properly. Also got the rocker panels lined up and the drip rails installed. Next up will be the trunk drops, tail panel and filler panel. After that it’ll be the A-pillar panels, roof panel and the top inner and outer cowl panels, etc. Didn’t take many pics but here’s a shot...sorry about the poor quality!
Shane
#theanchorholds
The Following 2 Users Say Thank You to Gmachine1911 For This Useful Post:
Roscoe03 (03-02-2020), warhawkchevelle (03-04-2020)
  #59
Old 03-13-2020, 04:55 PM
Thought I’d share an update...nothing earth shattering but it’s getting closer. Should be done next week, just needing to get the A-pillar patch panels and roof installed then the upper cowl can be welded on. The plan is to get it home and on the rotisserie so I can dress some welds on the underside, get the Quadralink installed and finish filling the firewall holes. From there it’ll get bead blasted and put in epoxy primer. Im very happy with how everything is coming together, especially given where I started at with it. Thanks for looking!
Shane
#theanchorholds
The Following 3 Users Say Thank You to Gmachine1911 For This Useful Post:
camcojb (03-19-2020), Goosesdad (03-17-2020), Roscoe03 (03-13-2020)
  #60
Old 03-14-2020, 08:18 AM
Steve68 Steve68 is offline
SSS, its actually starting to look like a car again, not to bad....
