Old 07-01-2022, 02:37 PM
Stielow's Avatar
Stielow Stielow is offline
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
Roscoe03 (07-01-2022), syborg tt (07-31-2022)
  #52
Old 07-01-2022, 05:39 PM
NAPA 68 NAPA 68 is offline
Lot's of room for an intercooler there
Old 07-02-2022, 04:41 PM
CarlC CarlC is offline
So much want for that airbox to fit in the Camaro.......
http:www.vaporworx.com
The Following 2 Users Say Thank You to CarlC For This Useful Post:
fleet (07-08-2022), Stielow (07-02-2022)
  #54
Old 07-07-2022, 02:19 PM
Stielow's Avatar
Look Carl! VaporWorx stuff!
Repo 30 gallon tank. VaporWorx ring. 2018 Tahoe fuel pump module with fuel level sending unit.
Stielow Engineering
The Following 7 Users Say Thank You to Stielow For This Useful Post:
camcojb (07-07-2022), dhutton (07-07-2022), fleet (07-08-2022), kwhizz (07-09-2022), NAPA 68 (07-07-2022), Roscoe03 (07-07-2022), syborg tt (07-31-2022)
  #55
Old 07-08-2022, 12:45 AM
Matt's fab skills can make anybody's junk look good!
Old 07-08-2022, 05:59 AM
130fe 130fe is offline
Thumbs up
Mark, are you using the GMPP controller to control the pwm fans? I see the AC pressure switch added in.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
The Following User Says Thank You to 130fe For This Useful Post:
  #57
Old 07-08-2022, 01:11 PM
Stielow's Avatar
Yes, it is a E67 controller so it will run the PWM fans and the AC pressure input.
I need to go into the cal via HP Tuners and fix that in the cal.
Stielow Engineering
130fe (07-08-2022), syborg tt (07-31-2022)
  #58
Old 07-08-2022, 01:21 PM
Stielow's Avatar
All the little details!
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
kwhizz (07-09-2022), Roscoe03 (07-08-2022), syborg tt (07-31-2022)
  #59
Old 07-08-2022, 11:32 PM
Steve68 Steve68 is offline
Covering all the A/C lines crimped fittings with the heat shrink! Nice and pretty!
Remember neatness counts!
I used to tell this to the techs building the Antares, ISS resupply rocket from Wallops Isl. Virginia
Old 07-09-2022, 02:50 AM
Jimbo1367 Jimbo1367 is offline
Default Recirculating bottle
Mark,
What is the bottle in front of the A/C pcs. that has TWO lines going to it? I think*** it’s the recirculating bottle/tank. Where do the two lines go?
Thanks,
Jimbo
