Old 09-30-2012, 07:42 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Hi Wayne:
I hope all is going well with your hip replacement surgery. If it's any consolation- my wife has had both of her hips replaced at the ripe old age of 36. (they replaced them 3 months apart) She was standing the same day she had the surgery, and, now two years later she is doing well.
I hope you have a speedy recovery.
-Brendon
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 09-30-2012, 08:15 PM
Hi guys thanks for checking in. I'm doing ok, this doctor seems to be very cautious because of the damage the recalled hip did. I don't go to see him for 6 weeks from the date of the operation. Only having trouble with strength in the leg. Just started walking around the block so its going pretty good now. I went in the garage to keep my sanity. Couldn't do anything but it felt good.
Old 09-30-2012, 08:24 PM
Good to hear!!!
Around the block is pretty good huh?!
Old 09-30-2012, 08:29 PM
Nothing ever felt so good! Well almost.
Old 09-30-2012, 08:39 PM
I did pick up a new set of 42 lb Holley injectors . I had 50's and was told they were a little big.
Old 09-30-2012, 08:59 PM
40#'s will support 520 HP
42#'s will support 550 HP
50#'s will support 620 HP
Above is at the flywheel not rear wheel hp. and using 43 #'s of fuel pressure using .5 BSFC (Brake specific fuel consumption) and 80% max duty cycle.
As with all fuel injectors you can raise their fuel rate by raising the fuel pressure. 42's @ 43PSI will become 45.3's @ 50PSI and so on.
Old 09-30-2012, 09:13 PM
I have a Weldon fuel pump its good to 90 psi. I plan on boosting the pressure to get what I need.
Old 09-30-2012, 09:19 PM
I'd also run a vacuum referenced fuel regulator... big injectors are hard to control at idle if you don't use a referenced regulator.
With a referenced regulator - the fuel pressure will DROP accordingly at idle (high vacuum conditions) and that will help with the pulse width management.
Old 09-30-2012, 09:23 PM
I have an Aeromotive referance regulator and a Weldon pump controller .
I have a question. I have an MSD 6A , will the new Digital 6A give me any advantage?
Old 10-01-2012, 07:26 AM
Quick answer -- not that I can think of.
BUT -- there's always a big butt somewhere right? The MSD can wreck havoc on your EFI if done incorrectly!
Make certain that there are no shared wire runs -- and that the MSD and ECU are AT LEAST 2 feet apart.
MSD boxes are very powerful and if you want all manor of problems and weird issues just fail to heed the warnings.
