Old 10-02-2016, 08:38 PM
Thank you! I love it.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 10-03-2016, 09:54 AM
DOOM's Avatar
DOOM DOOM is offline
Originally Posted by will69camaro View Post
No joke. I got a friend to do it after he commented on only having a certain amount in the car he figured. It sounded very low so I said "add it up." Ended up being 30-40% more than he had anticipated.
I think the best advice I can share that I've learned is if you have 60k to build a car, plan to spend 30-40k and you MIGHT finish it before running out of cash.
I would say that's pretty much it . I never in a million years thought I would spend that much on a automobile .
Mario
USCOLLISION
Old 10-03-2016, 05:30 PM
Centerforce's Avatar
Centerforce Centerforce is offline
Those are some GOOD noises coming out!
Old 10-03-2016, 06:33 PM
Agreed!!! I want MORE!!!
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 10-03-2016, 08:18 PM
MtotheIKEo MtotheIKEo is offline
Congrats on the first drive. This has been a fun project to watch.
Old 10-03-2016, 08:37 PM
Hope it's more entertaining now that it's going!!!
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 10-04-2016, 06:12 PM
BigBronco's Avatar
BigBronco BigBronco is offline
Can't wait man! Looking forward to getting this thing buttoned up.
2022 F-350 Tremor | Daily Driver
1972 Nova | LSX | 6 Speed | Speedtech Suspension | C6 z06 Brakes | Forgelines
1968 Firebird | LM7 Swap | 4L60e | Ridetech Suspension | C6 Brakes
2012 Corvette ZR1 | Bolt-Ons | Forgelines
2001 Trans-Am WS6 | Cam | Six Speed | Slow
1969 Mach 1 Fastback | New Project
Old 10-18-2016, 05:54 AM
It was a tough vacation out of the country after driving the car as all i could think about was getting back to work on it. After 8 days gone, i landed mid day Saturday and went right back into the garage to do some test fitting.
Headliner arrived while I was away so I had a friend put it in my garage and take it out of the box for some inspection. Looks good! (thanks MCB for rushing TMI to beat their 4-6 week lead time, and thanks TMI for making it happen!)
TMI One-piece in bedford grain vinyl.
As soon as I got home, I went to put it in, to see if it would clear the cage.
Tough with one person but I got it over the main hoop which was my primary concern! Has some minor interference in the back but I think with a second set of hands, it'll be no major issue to get it past.
Headliner came back out and thermal insulation and finishing the dynamat became the objective. Seats came back out and will remain out till carpet is installed.
While waiting on the carpet to "relax" i took to the front end. Getting the headlight buckets mounted proved more difficult than just bolting them in, as the intercoolers occupy some shared space. Minor modifications and they're in.
Since it shares some hardware I also installed the autorad coolant overflow. Moved slightly as the supplied bracket doesn't fit with the turbo kit. Using a mount from MightyMouse (catch can mount) I secured the overflow to it's new home.
I had some difficulty getting the lower fender extensions and the lower valence installed. Aftermarket valence and original extensions. Definitely was not fun, filing and cutting on a painted piece to make it line up correctly. Gotta love old cars and fit/finish!
(Sorry for the bad pic, too much backlight in the garage for a good front shot with the front panels installed.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 10-18-2016, 09:14 AM
lsuguy's Avatar
lsuguy lsuguy is offline
Looking good man! I had to axe the overflow can from AutoRad as well. The included mounting solution puts it right in the way of where I plan to plumb my intake tube. I keep telling myself if you fit allllll of that turbo plumbing I should be able to install this NA motor no problem
Old 10-18-2016, 10:30 AM
HAH definitely. The design they have is good, just restricts a lot of space on the drivers side. I like where it ended up getting mounted. All close proximity but it works.
Need to get the hose hooked up for the overflow though.
William
Texas A&M BSME 2008
1992 Corvette ZR-1
