Old 04-02-2015, 09:51 AM
Flash68's Avatar
Flash68 Flash68 is offline
Originally Posted by Payton King View Post
Dave's motor and mine are about the same minus my Aluminum block.
We are Carolina cousins (I think that means married or something?)
I do envy your alum block, shorter stroke and EFI.... gonna be very cool.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 04-02-2015, 12:49 PM
bergers59 bergers59 is offline
What kind fittings/clamps are those where the braided line meets hard line?
Old 04-02-2015, 01:21 PM
Flash68's Avatar
Wiggins
2014 4 tap Keezer
Old 04-02-2015, 04:12 PM
Sieg's Avatar
Sieg Sieg is offline
Wiggins
Flash has socks that match them.
Old 04-02-2015, 04:46 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Dave's car had me at the Ford stripes, but this one keeps pulling me back in with its aluminum block, short(er) stroke goodness, not to mention all the Brown and Miller stuff!
Old 04-02-2015, 05:46 PM
Che70velle's Avatar
Don't forget about the neck tie...
Thanks Dad!!
Old 04-17-2015, 04:38 AM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
Nice Bro Truck! Hahah.
Where the skulls done by a previous owner?
That truck doesn't look like it will fit in your garage - my Duramax 2500 barely fits in mine.
Love the updates to the Camaro - we going to get a chance to see engine dyno vids anytime soon? What kind of EFI are you using - the TB based Holley unit?
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 04-17-2015, 06:38 AM
Payton King's Avatar
Yes, all the custom work was done by the previous owner. Frank Garcia, who was the center for the Carolina Panthers.
No way is that truck fitting in my garage. Top of the roof is 7'2"
Pistons and rings just came in so all I need is head studs and a cam. Motor vids are a few months away. Have not decided on an injection system, either AEM or Holley. May have a line on a throttle body off of an RO7.
What amazes me is I will be running an LS firing order and we called Comp cams. They have 50mm, SB2 cam blanks with an LS firing order sitting on the shelf. Just need to come up with specs to have it ground.
Old 04-17-2015, 07:31 AM
Graham08's Avatar
Graham08 Graham08 is offline
Very cool build! I've been following this for quite a while, just haven't commented yet.
Is the LS firing order the same thing as a 4-7 swap for a 1st Gen SBC? If that's the case, it doesn't shock me that they have the blanks on the shelf. It's pretty common for race engines, both SBC and BBC.
On edit: I see it's not the same. It's a 4-7 and 2-3 swap relative to the 1st Gen engines. That is interesting the blanks were on the shelf.
Old 04-17-2015, 10:38 AM
I was doing it mostly for the type of electtonics I was originally going to run, but later found out it is good for about 5 HP. Not that I need 5 more HP but all the serious guys do. I think the RO7 runs that same order.
