Old 01-18-2021, 07:09 AM
Jimbo1367 Jimbo1367 is offline
The government wouldn’t allow this new. Stiffer crash/ roll over guidelines now , I bet anyways. That’s why the concept Challanger changed so much with production cars. I bet usage of existing under pinnings might of helped the change in production cars too. I’m a Chevy guy, but the concept Challanger looked great. Made me consider buying a new car.
Old 01-18-2021, 07:58 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by DKz Garage View Post
Car looks fantastic Mark, as do all your builds!! Any chance you know the part number on the power brake vacuum hose??
Just two Gates 1/2 hoses with a molded in 90 degree bends. Ask your parts store for them.
Stielow Engineering
Old 01-19-2021, 04:01 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Just in time for the Riddler competition !!!!!
Old 01-19-2021, 05:29 AM
k7king's Avatar
k7king k7king is offline
Default Ac
Mark
Do you use the ecm to control the cooling fans? Curious to what everyone does to control the fans with AC request?
Thanks and beautiful build.
www.kingind.com
www.ridetech.com
US Mag Wheels
Old 01-19-2021, 05:32 AM
Stielow's Avatar
Originally Posted by k7king View Post
Mark
Yes I use the ECM to PWM the fans. This is not how the GM crate cal is set up. I have to make a new cal to do that.
The fan runs off 3 inputs - Coolant Temp, AC head pressure and inlet air temp post intercooler bricks.
Mark
Stielow Engineering
Old 01-19-2021, 06:25 AM
k7king's Avatar
Ok.Thanks I've intalled a few gm crate engines with gmpp computers and used the fan wire from the gmpp harness but there isn't a way to tell it when AC is turned on unfortunately.
www.kingind.com
www.ridetech.com
US Mag Wheels
Old 01-19-2021, 10:21 AM
camcojb camcojb is offline
You can use a trinary switch on the a/c line, so the computer controls the fans whenever the a/c is off, and once the a/c is on the switch bypasses the computer control and turns the fans on automatically. I'm going to be using a standalone PWM controller for my twin Ron Davis fans.
https://lateral-g.net/forums/showthread.php?t=58472
Old 01-19-2021, 12:05 PM
cpd004's Avatar
cpd004 cpd004 is offline
Correct me if I'm wrong, but the GM ECM doesn't use a trinary switch when controlling fans by way of PWM.
1971 Firebird
2017 SS
Old 01-19-2021, 12:17 PM
Blackhawk's Avatar
Blackhawk Blackhawk is offline
Doesn't get much cleaner than this, the wheel fitment is also perfect! Can't wait to see how it does on the street & track.
Old 01-20-2021, 06:20 PM
67_camaroRS's Avatar
67_camaroRS 67_camaroRS is offline
Mark have ever had issues with the latch in the hood popping open at high speeds? I'm not sure if your using the original latch mechanism. I've noticed many car builders use hood pins and my father before me has warn me about the risk at high speeds. thanks sir.
1967 Camaro RS
1969 Camaro coupe
