Been way too long since I posted an update on this site. Make lots of progress in the past months.. here goes:
Had my first issue with Ebay.. thankfully it turned out OK in the end. I bought a set of Fox body tubular front control arms which I thought were made by Maximumum Motorsports (one of the highest quality Mustang tubular control arms you can buy). Got them in and they did not look right or fit right. Sitting 5 feet away they looked like the real deal. Turns out in the end they were knock-offs from another company. Once I convinced the seller they were not legit (he was not aware either), I got my money back and send them back. In the meantime I was able to convince someone to trade me straight up for the ones I had already. As you can see, they are much shorter which works out perfect. I now have lots of tire clearance and should be able to fit 275's up front which was the original goal (2004 Cobra used this size).
First problem after installing new arms - tire rods are too long. Solution - 1993 Taurus outer rod ends. Works great now.
Also aborted mission for now on the tubular k-member. Too much time and money for the time being. The stock k-member is likely stronger regardless. In that case - started to work on getting the motor mount brackets modified to get the engine shifted back as far as possible.
Unfortunately with the Fox control arms being used, this also means the upper strut mount needs to move inboard to be able to get the alignment settings right. This meant we needed to cut up the jig and make it adjustable using threaded rods and nuts.
The goal here is to be able to set the front wheels to 2-3° of neg camber for the track, and then adjust them back to 0.5° neg camber for the street. The caster is also being increased relative to stock. Looks like 275's will fit up front when using the 0.5° setting which is great news.
All that is needed to set things into position is to flip the camber plates upside down and swap side to side. This way they can be bolted to the jig. Next max the camber setting inboard and then take suspension measurements. Keep adjusting the fixture outboard until the max neg camber is achieved. After this, unbolt and put on shock towers. Lots more sheetmetal work ahead, but it should hopefully work out in the end. Turns out the inner surface of the shock towers is almost flush with the origional fram rail which make things easier fab wise.
