Old 06-01-2010, 07:28 AM
Karl Buchka Karl Buchka is offline
Originally Posted by MSTSFabbed View Post
Amazing. Those look great! Looks like tigging in those cross peices on the uprights is gonna suck haha.
Thanks! The spokes should be simple compared to the rest of uprights.
Originally Posted by frojoe View Post
This fabrication work is awesome, good job on not only the research & modeling, but carrying through with it too.
And hip hip hooray for Solidworks, anything you can dream up can be a reality when solid modeling!!
Thank you! There are plenty of parametric modeling packages out there, but I much prefer SolidWorks. It has the most intuitive and user friendly GUI imo.
Put in another all-nighter last night. Alex and I got the uprights completely tacked. After we drill a few mounting holes they'll be ready for mock-up on the front end.
Missing two 2mm shear plates and filler. Looks like we're on track for weight (CAD says 3.49kg).
'82 Volvo
Old 06-01-2010, 04:19 PM
70rs's Avatar
70rs 70rs is offline
Looking really good as usual.
Eric
Old 06-02-2010, 07:52 AM
Bryce Bryce is offline
WOW, I just saw this thread for the first time. You guys do great work.
Old 06-02-2010, 05:18 PM
frojoe's Avatar
frojoe frojoe is offline
This is definitely true, after using Inventor, Unigraphics, and Pro-E (holy steep learning curve!!!) SW is definitely the funnest one
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
Old 06-06-2010, 09:13 PM
Thanks guys!
Just got back to the states yesterday and I couldn't resist bolting up an adapter on one of the rear wheels:
'82 Volvo
Old 04-19-2011, 05:27 PM
Sincere apologies for the lack of updates. Both my brother and I hit on some hard times recently and our car hobby was relegated to a fairly distant back seat. Things are looking better now though, so we're excited to make up for some lost time.
Here's the car in its current state. We removed all the strut sheetmetal and exposed the frame rails.
I did this back in December. Gas pedal for the billet pedal box. It came out beautifully. The pictures really don't do it justice.
My brother Alex has been putting in serious time in CAD lately. Uprights are starting to resemble something useful after about the 20th from-scratch redraw. The old uprights had to be scrapped due to some major packaging issues. The pictured upper control arm mount on the uprights are probably pretty close to what the final version will be. Should be plenty strong with the whole thing made from welded 4130 sheet. He also completely revised the frame tubes and upper coilover mounts to what we consider a completely reasonable solution.
This is showing at ride height. Upper control arm mounts will basically be something like this with the cross tubes attached to the frame tubes with judicious amounts of .065" sheet. The camber adjustment should allow us to dial in up to -5 degrees of camber without impacting the steering axis inclination. The track rod is obviously a place holder for the real one (see below).
Full bump and full left steering input. It's looking like the wheel angle at full lock will be about 30 degrees for a curb to curb turning circle of ~10m.
Ride height with the frame rail hidden. The sheet around the lower control arm mount and the track rod mount are not the final version. Still trying to wrap our heads around that 3d puzzle.
The brake caliper mounts are pending a revision of the calipers themselves.
The steering rack is mounted forward and below the axle centerline and parallel with the front lower control arm hard points to minimize bumpsteer (it's at around 0.3 degrees at full bump and droop). The way it's all laid out means the wheel and track rod try to occupy the same space at full bump and full steering lock. Alex drew up the outer track rod so it dodges the wheel. Making it machined 4130 with a captured 1/2" uniball. Some cursory FEA gives us a FOS exceeding 3 with a 10kN load applied along the steering arm axis.
Scored big time on eBay. 30k mile C5 diff for under $200 shipped.
Also found a largely complete torque tube:
The entire assembly obviously needs to be shortened quite a bit. We haven't done any measuring yet, but we're hoping the input shaft length and torque tube bolt pattern allow for a simple adapter plate arrangement with the Volvo bellhousing.
With the diff and torque tube we finally have all the major driveline components (clutch, flywheel, transmission, diff, torque tube, and driveshaft). A buddy of ours has a Faro arm that I'm hoping to use this summer to digitize the transmission and diff casings. Should make the CAD for the rear suspension nice and simple.
'82 Volvo
Old 04-19-2011, 05:33 PM
HWY Nova HWY Nova is offline
Great CAD layouts!!!!!!!
--Eric
ET
62 Nova Coupe
62 Nova Convertible @ Ironworks Speed & Kustom
Old 04-20-2011, 12:07 AM
novaboy7272's Avatar
novaboy7272 novaboy7272 is offline
this build looks crazy sweet guys. Gives me motivation to keep going on whatever i'm doin haha. Keep up the great work. . .AND PICTURES
Andy Kacura-Miller
Old 04-20-2011, 06:02 AM
elitecustombody's Avatar
Can't wait to see it together,it's going to be one trick Volvo
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 04-26-2011, 03:35 PM
--Eric
Thanks guys. The kind words are always much appreciated!
Time for a small update.
Here's what a "permanently sealed" STS-V/C5 Corvette hub/bearing assembly that's been permanently disassembled looks like. Turns out they're more user serviceable than Timken would lead you to believe.
Pop off the ABS sensor cover, pull the ABS trigger wheel off, then remove this two-piece retaining ring. After that it presses apart easily (too bad we didn't figure this out until after we had wailed on it in a 40 metric ton press).
Disassembling the hubs makes it easier to modify the bolt pattern and center bore.
CAD update: Alex did a ground-up redesign of the front brake calipers. The basic piston layout and pad is the same, but these are lighter, easier to machine, use smaller stock, deflect significantly less, and look about 100x more bad ass than the old ones.
'82 Volvo
