Originally Posted by ccracin
Jim,
Send me the sketches and I'll model it for you!
Chad delivered on the models for the welding table - man that guy is good !!
Used many of the ideas posted here. 30 x 48. 1/2 steel top to reduce weight. No front lower cross bar so I can sit under and weld. Levelers with casters. 4 inch grid pattern drilled into the top to accept 3/8 NC machinest clamps and blocks. 2 electrical outlet on the front cross bar (1 left - 1 right) to plug in grinders and stuff. Racks down the left and right legs to hang stuff - in my case left rack is for 1 inch to 10 inch C clamps. The right side is for grinders and fender vise grips on first hanger and normal vise grips on the other. A 12 inch deep shelf on the bottom to hold equipment mounted to 12 x 12 plates that attach to the welding top (shrinkers, tube bender, tube notcher, T-posts, vise, etc) and a removable 3 piece grinding screen to help control the crud spray.
Chad is still adding to the design with a full length drawer under the top to catch the crud coming thru the table grid and we're working on a 5 inch deep cabinet that mounts under the table and between the back 2 legs to store consumables (mig rolls, rod, tips, cups, liners, etc)
And did I say - Chad is the Man !
Jim
