Old 09-02-2010, 08:46 PM
I don't see a center line --- you got that bad boy squared up in there do ya??
Just checking.....
Old 09-02-2010, 09:17 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
you mean the engine center in the frame? if thats what you mean then no. the engine sits to the pasenger side because of the steering gear. thats what roger speed tech told be that they do because of the power steering lines. it was either off set the engine of raise it really high to clear. if i remember i'll try and get a picture of that tomorrow.
Old 11-04-2010, 08:46 PM
CamaroAJ's Avatar
haven't had time to do a whole lot to the car in the past few weeks but here is what i have.
got the driver and passenger fill template done to make things look better after cutting out the package tray.
got to wiring the engine in. i'm about done with that and then on to the forward chassis harness and then dash harness and then rear chassis harness.
so far this is what i have removed from the stock gm engine and forward chassis harness.
98% done engine harness done. i still have a few things to finish up once i build the cold air intake and go to jegs to get some more wire loom.
also have the double pass radiator. it also will be set back 7" just like the engine. i'll be working on this more later once i get the bead roller for some of the tin work.
also for the first time since april the car has seen sun light. still waiting on the rear suspension so its on jack stands in the rear.
when i bought it
and now
Old 11-14-2010, 07:47 PM
CamaroAJ's Avatar
not much of an update since its hard to take pictures of wiring.
got the fuse blocks mounted
the lamp harness and some of the ECM wires.
the main harness to the firewall is done and most of the wires are to the location they need to be and just need tied up.
got the EBCM mounted and the harness lengthened
so at work on friday we are throwing out all of the GM parts from when we were a Chevy dealer and i found this. its a rear HVAC module from an '03-'06 envoy extended.
because of the '01 dash conversion i did and the fire wall mods for the engine set back i had a TON of room. after some mock up and then putting the dash back in it fit!
Old 11-14-2010, 09:49 PM
Awesome dedication on this thing! Seems like a project I would try and tackle if I had the funds. One question, on the engine mount in this picture:
This could be me over engineering, but I feel like there is a need to triangulate that mount.
1/12th scale 1969 Sunset Orange Metallic Camaro Pro Touring Style>>
Progress Thread
Artwork Page
Old 11-15-2010, 03:27 AM
Tiger's Avatar
Tiger Tiger is offline
I would triangulate that mount, maybe its as you say over engineering but better safe than sorry.
André
2009 Chrysler 300C Touring.
3.0 liter V6 diesel, five speed auto.
1968 Chevelle Coupe.
355cid, Viper T56, Corvette C4 IRS (Dana 44) and C4 IFS. Porsche 6 and 4 piston Brembo's.
1980 Chevy Van (shortie G10).
355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
*NOW PARTING OUT* 2000 BMW 540i Wagon*
Bikes
1968 Benelli City Bike
1990 Yamaha RD 350
1990 Yamaha TZR 125R
1991 Yamaha TZR 125R - RD350 engine, Aprilia RSV forks, RS250 wheels and shock
2010 Buell XB12SS
Old 11-15-2010, 09:03 AM
CamaroAJ's Avatar
the engine mounts are not done yet, good eyes guys and i was thinking the same thing. i was waiting on getting my steering column mounted so i knew what kind of clearance i have just in case.
i plan on running i brace from the top of the mount forward to the frame on each side. i was concerned about the engine moving forward and back under hard braking and accell.
Old 11-15-2010, 11:19 AM
If I were building those mounts. I would triangulate directly back to the frame, joining your upright with the sub frame. This will add some strength to that joint, and should keep the motor mount from moving. Or, if you are worried about movement front to back, bring the mount front and back, essentially creating a pyramid.
Progress Thread
Artwork Page
Old 11-15-2010, 11:38 AM
It looks good. Thats a lot of wire!
Old 11-29-2010, 06:47 PM
CamaroAJ's Avatar
i decided to make my own LED tail lamps because i don't care for any of the aftermarket ones that are out. its also cheeper that the awesome billet one. its not done because i ran out of LED's but two thirds of its done. then i get to start on the passenger side and even more LED's. at least i'll be seen when i stop.
doesn't look pretty but its a pain to wire that many LED's and not short them together.
i seem to have a problem getting a picture of LED's turned on. this is 2 of the 3 park lamps on. it is the perimeter of each lens for park lamps and the center of the outside lenses are brake lamps.
i took an angled shot to get a picture. when i take a straight on shot its too bright and blurry. brake light on.
i also have back up lamps
