Old 01-23-2013, 06:31 AM
wrp's Avatar
wrp wrp is offline
Absolutely beautiful job. Congratulations
Old 01-24-2013, 11:13 PM
igoslow's Avatar
igoslow igoslow is offline
How did those new seats fit?
Old 04-12-2013, 06:29 AM
CFster CFster is offline
Installed some J-pipes. They help with exhaust drone significantly!
'67 GTO - LS3, 4L60E, SC&C AFX Package, KORE3 C6 Z06, Boyds PT-09s
'67 GTO LS3 Swap
Old 04-12-2013, 08:22 AM
66fury's Avatar
66fury 66fury is offline
Please explain the j pipes, are they capped ?or have some special end?
Old 04-12-2013, 06:25 PM
They're capped. What happens is sound waves come into the pipe, then are bounced back in an inverse pattern - which cancels out the noise. Reduces drone considerably. There is a formula to determine what length your j-pipes should be, based on what hertz range you're getting the loudest noise. An easier approach is to order these adjustable ones from Solo Performance. Then it was a little trial and error - loosen the clamps, slide them out 1/2", test drive, repeat.
'67 GTO LS3 Swap
Old 04-12-2013, 10:21 PM
67goatman455 67goatman455 is offline
Very nice, i had just read about that method the other day. looking good!
1967 GTO, LS2 T56
WILWOOD FORGELINE RIDETECH
$10k Budget driver/ track car
Old 04-13-2013, 03:29 PM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
I was about to mention Solo - but you already did.
My buddy has those on his 2010 Camaro and they sound damn good.
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
