Old 06-19-2017, 03:02 PM
TheShopLLC.com TheShopLLC.com is offline
Be sure to check out our online store. Thanks a ton Lateral G!
https://the-shop-llc.myshopify.com/p...nclosure-combo
TheShopLLC.com
Old 07-01-2017, 05:56 AM
DT69Cam DT69Cam is offline
I just received my kick panels. Man, these things look awesome!!! I'm going to have to drill 3 NEW mounting holes, trim the E-Brake bracket, and move the floor dimmer switch for them to install. I was hoping the 3 mounting holes (on new panels) would line up with existing mounting points, that's a no go for my 69. Also its a good idea to adjust the E-Brake pedal (tighten up) so as to limit travel of the pedal, otherwise the pedal will hit the kick panel.
69 Camaro Convertible (LS3/TKO in the works)
Old 07-07-2017, 06:52 AM
Thanks a ton for the purchase and the feed back, it seems that most of these installs do vary slightly from one to another with the e brake and dimmer switch. We have had a few in the shop that were easy peasy and a few where the E brake dose get just a a slight trim. Thanks again!
TheShopLLC.com
Old 07-07-2017, 06:53 AM
A quick trim to the e brake and the kick will slide right in, as far as tweeters, if you can get them up higher in a pillar or door panel that would be best, if not, run a coax component in the kick.. Here are a few pics of the e brake.. We can pop a hole under the 6.5 for a tweeter there is plenty of room.. Thanks for the feed back guys
TheShopLLC.com
Old 07-07-2017, 10:51 AM
Oleyellar Oleyellar is offline
Default Ordered mine this week
Looking forward to receiving my order. I think it's the best looking setup around. Hope mods are kept to a minimum. It is tight under the dash as it is, and I have already had issues with the emergency brake light switch and the AWW wire harness fuse block.
Thanks.
Old 09-20-2018, 07:21 PM
HIFLYR's Avatar
HIFLYR HIFLYR is offline
Anybody had issues getting their order from the shop llc?
69 Firebird Convertible
68 Camaro Convertible
68 Firebird H.O. 350 4sp
73 Allison Dune Buggy
Old 09-23-2018, 02:34 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Not that I've heard of. Mine arrived right on time. Give them a call. Great people to deal with.
Curtis
Old 09-26-2018, 09:02 PM
alongfortheride alongfortheride is offline
Screamin performance kicks fit with out any modification on my 67 Camaro. Clear ebrake and are perfect
Old 11-27-2018, 07:15 AM
TheShopLLC.com
The Following User Says Thank You to TheShopLLC.com For This Useful Post:
camcojb (02-12-2019)
  #70
Old 12-17-2018, 05:08 AM
absinthe absinthe is offline
Ive been on your site, but i cant seem to find where the kickpanels are sold separately. Are thry? I am not interested in the package tray or sub enclosure.
Thank you
