Old 07-23-2017, 08:03 AM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
Any updates?
Jose
Old 07-31-2017, 12:48 PM
V8TV's Avatar
V8TV V8TV is offline
Many have asked, the mirror base is wedge-shaped to pitch the mirror properly.
The Impala originally had large, flat-topped rib starting on the header panel and running up the hood. We are building a custom hood for this car, and the customer didn’t want that flattened rib, so we reshaped the header to come to a peak to match the new hood design.
After some cutting and reshaping, the header now has the pointy peak.
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
Old 07-31-2017, 01:18 PM
Nice job. It will be one of those changes most will miss but the guy into these cars will pick up and appreciate it.
Old 07-31-2017, 04:24 PM
gofastwclass gofastwclass is offline
Very cool. I love subtle changes more than the over the top ones. Excellent work.
I build my own junk...
Old 08-01-2017, 05:55 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Love seeing the metal fab.
Old 09-17-2017, 05:28 PM
V8TV's Avatar
Thank you gents!
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 09-17-2017, 05:30 PM
V8TV's Avatar
Allright, it was time to address some of the Impala’s wobbly chassis issues. This car had a bit of rust that needed repairing, and we took some time to install some .120” wall tubing to brace up the chassis.
First up was the custom transmission cross member.
The pin-bolt design is strong and also allows for a quick removal if needed.
MagnaFlow exhaust will have to make it’s way around the bottom of the car.
These cars are tricky with the multi-link rear suspension, and we wanted to run full-length exhaust all the way to the back, so everything needed to be built with all the pieces in mind.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 09-17-2017, 05:31 PM
V8TV's Avatar
Clearance issue on the panhard (track) bar and the preload caps on the 12-bolt rear end cover…
Solution: Extend the panhard mount, but make sure the geometry is correct and that it is strong enough.
There you go!
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 09-17-2017, 05:36 PM
It looks pretty strong to me!
Old 09-25-2017, 10:31 AM
V8TV's Avatar
Finishing up the transmission crossmember
These holes are good for ˝ second faster times in the quarter mile.
Some additional bracing was added from the transmission cross member to the frame.
Big mounting feet for bolt-in installation.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
