Old 04-03-2017, 07:01 PM
tgvettes tgvettes is offline
I really like this project. cool with something different!
Tonny
1980 Volvo 262 C Pro Touring Project
Old 07-08-2017, 12:44 PM
gmc gmc is offline
Any progress? This one takes me back, my first car was a red 77 hatchback.
Old 08-23-2017, 07:53 AM
GPR's Avatar
GPR GPR is offline
We were moving cars around and I thought it was a good time for a couple of photos while it was outside.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 08-30-2017, 06:27 PM
YAMATHUMP's Avatar
YAMATHUMP YAMATHUMP is offline
Looking Good!
Brad
83 Chevy c10
Old 11-24-2017, 07:04 AM
GPR's Avatar
GPR GPR is offline
I made a little progress on the Mustang II project. I have the gas tank installed
I modified fuel filler tubes from an Eleanor project that we didn't use to fit the II
Epoxy primed
Front sway bar installed
Rear brakes left over from a Wilwood upgrade on another project
Gas cap
Rusty Gillis
Port Richey Fl
Old 02-10-2018, 02:57 PM
GPR's Avatar
GPR GPR is offline
I just traded a C6 transmission and converter that was used in my race car (now use a C4 behind the 428 CJ) for this 302 that has very few hours on it to install in my Mustang II
Rusty Gillis
Port Richey Fl
Old 02-17-2018, 06:49 PM
GPR's Avatar
GPR GPR is offline
Today the 302 was dropped off at the shop. It was in a Mustang that was upgraded to a 427 small block.
Looks new
I need to order a flex plate for the AOD. I'm also going to replace the water pump, harmonic balancer, fuel pump, intake and valve covers plus the correct oil pan for the Mustang II.
Now I need to get busy installing brake lines and fuel line before I install the engine.
Rusty Gillis
Port Richey Fl
Old 03-24-2018, 07:15 PM
GPR's Avatar
GPR GPR is offline
I ordered a Ron Francis wiring harness and after looking at the back of the dash and seeing wires held together with masking tape I decided to remove everything and start over.
I will have to enlarge the openings to fit the new 4" Speedhut speedometer and tach that I ordered
I will also have to modify the dash to fit the 2 1/16" gauges
Rusty Gillis
Port Richey Fl
The Following User Says Thank You to GPR For This Useful Post:
camcojb (03-24-2018)
  #69
Old 03-25-2018, 09:35 AM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
Do remember the 1978 Mustang Monroe Handler of that era.
Old 04-23-2018, 05:18 AM
GPR's Avatar
GPR GPR is offline
Speedhut gauges came in. Each gauge has a bag with wires, sending unit or whatever is needed to hook it up.
I have to modify the back side of the gauge panel.
I used a half round file to enlarge the hole.
I still have to paint the dash trim black
Rusty Gillis
Port Richey Fl
