Old 01-06-2016, 03:44 PM
kwhizz's Avatar
kwhizz kwhizz is offline
Just to get everything up to date...........I ordered a Concept 1 Front Drive set-up, and with this set-up........I had to take the snout off the supercharger and send it off to Lingenfelter Performance for modifications that are required for the new Pulley set-up.........So......I have been waiting for these items to arrive.........the Snout arrived today so I put the unit back together.....Hopefully the front drive itself will show up later this week..........
Old 01-09-2016, 04:14 AM
kwhizz's Avatar
Here's a picture trail on the progress on the dash cluster.........When I got the car is had faded chrome on the cluster and the lower column cover......I sent them out and had the chrome stripped, then along with the cluster and cover I also sent the ash tray and glove box door to Puleras for painting...........the guy's at Puleras hit a home run again as far as matching the paint and the quality of the work done.........picked up the parts yesterday and installed the Dakota Digital VHX Gauges.....
Old 01-09-2016, 05:28 AM
kwhizz's Avatar
Now we get to the part I have been worried about..........Getting the 4L85E transmission into the car.....Get the car up on the lift and the moment of truth.......5 minutes later the trans is bolted in place with no issues at all.......plenty of clearance all around.......the 57 has an extremely large trans tunnel.........the Trans mount even bolted in place with two of the existing bolt holes.....But....After looking at the relation between the engine and the firewall, I may move the engine forward 1/2" to give the engine harness a little more room.........gonna check it out a little closer today...........
Old 01-09-2016, 08:50 AM
Looking great Ken!!
Was chuckling to myself with the transmission lift.... you have no idea how much stuff I've hoisted on mine! I've built all kinds of jigs for it even - to hold various parts - sometimes having nothing to do with cars. LOL
Old 01-11-2016, 05:00 PM
kwhizz's Avatar
I got another package today so I can move forward with getting the dash area finished up.........I just couldn't see putting the Vintage Air plastic swivel balls in the dash....... Found these ..........Gotta cut the openings and get the Duct work finished ......then I can get the gauge cluster back in.......Soon.......
Old 01-11-2016, 08:25 PM
Nice looking parts.
Old 01-12-2016, 07:42 AM
Nothing worse than a nice car with those NASTY plastic A/C outlets!
When I was re-doing the '56 Nomad -- I found a pair of perfect OEM A/C outlets... IIRC I paid about $500 for the pair at a swap meet. Nobody made repops back then.
The problem was - the compound curves - and I wasn't exactly certain of their location. Since the car was painted - I wasn't about to just hack away and rework an area... So lucky for me - I found a dash from a '56 A/C, and get this, also factory PADDED!! I've never seen one (padded) in a car. I bought the whole dash - and then I could make a pattern from that and cut my dash, and they fit perfectly. I still have that dash... for no other reason than I've never seen one.
I'd also made a "console" out of wood and bondo and metal.... because I loved to drive that car and needed a cup holder!!! LOL
The Following User Says Thank You to GregWeld For This Useful Post:
kwhizz (09-08-2024)
  #68
Old 01-12-2016, 09:05 AM
jy211's Avatar
jy211 jy211 is offline
it's a "pucker" moment when having to cut into a dash...
Old 01-14-2016, 04:59 PM
kwhizz's Avatar
After installing the Transmission for the trial fit and seeing how much room there really was around the trans.....I decided to remove it and put in the Converter for the final install.....this is actually going too easy, the cross member bolted in with two of the existing holes (just have to drill 2 to suit )......and today I took the driveshaft to get a new transmission yoke put on match the 4L85E trans........and the driveshaft fit's as is........Here are some pic's.......I also received the Concept 1 Front Drive system.......I'll get that installed over the weekend.....Pic's to follow
Old 01-15-2016, 01:32 PM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
Man you move fast!
I started my fuel upgrade project about the same time you started this thread...
I just got my Corvette running again this week - but that fuel project snow balled into a clutch replacement, speed bleeder install, rear main cover and gaskets, and new input bearing!
Good work Ken!
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
