Old 10-04-2017, 03:54 AM
vstol vstol is offline
Anyone heard that the E-brake should be engaged before bleeding the rear brakes. On the C4 it is just using the piston vice a rear drum unit.
Old 10-04-2017, 05:07 AM
dhutton dhutton is offline
I seem to recall that it needs to be properly adjusted. When they use that style caliper on some swaps you have to unbolt the caliper and rotate it so the bleeder is at the top to get all the air out. Not sure if that applies here.
Don
Old 10-04-2017, 05:59 PM
Just went Tobin (Kore3) suggestion and bought the CPP 15/16ths MC to fit my car then I might go with it boosted if this is not enough which should be fine. Std setup for manual is 1 inch bore. Thanks for all your help, I will let you know how it goes. This retired Marine has had enough.
Old 10-04-2017, 06:11 PM
Hope you have better luck with CPP masters than I have. I just had two that leaked badly through the plugged ports on the passenger side. Complete waste of time. Now waiting for a third that is supposedly using a different casting. I wanted to go with an AC Delco but the car owner is insisting on another CPP master.
Don
Old 10-05-2017, 03:59 AM
The attraction to CPP MC is it comes in 15/16ths. This is my second Wilwood MC at $200. Tobin has a great reputation so we will give this a try.
Old 10-05-2017, 09:29 AM
It might be a dumb theory, but I get the sense that adjustable proportioning valves make effective bleeding much more difficult, especially if the valve is set to close off one end of the system when you're bleeding. I say this because I've only had problems bleeding systems that have adjustable proportioning valves. With my current system (mostly new steel lines/bends/masters/pedal), which has no adjustable valve (dual masters with balance bar instead), basic gravity bleeding actually worked the first time (as far as I can tell at this point). I was so happy to avoid that stupid compressor suction setup . . .
Old 10-05-2017, 11:40 PM
Hydratech®'s Avatar
Hydratech® Hydratech® is offline
Supporting Manufacturer
HydratechBraking.com
Post Low cost OEM MC's for bore size test purposes
FYI - I see people spending all kinds of money on expensive master cylinders, swapping them out for different bore sizes for test purposes to see what / if any improvements are to be had (brake feel tuning purposes). Here are some super low cost OE GM MC's that you should be aware of to use for initial bore size swap out test purposes:
7/8" bore manual brake: RAYBESTOS MC39027
(1977 Chevy Monza)
WARNING: This MC does NOT have the deep MC pushrod hole. You CAN drill the piston for a deeper pushrod hole, use a rubber boot to make sure the brake pedal rod doesn't accidentally fall out, or rig up a brake pedal rod retainer of sorts.
http://piratejack.net/master-cylinder-manual-rod-boot/
Here you can see how www.mpbrakes.com (Master Power Brake Company) takes late model MC's that are equipped with the short rod / shallow MC pushrod and then drills them for the deep pushrod hole for manual brake usage:
https://www.mpbrakes.com/images/MC39...earM-Large.jpg
BTW - You are looking at a 2000 +/- model year US S-10 MC that has been drilled for manual brake usage in the image link above.
15/16" bore manual brake: CARDONE SELECT 131639
(1977 Chevy Malibu - deep MC pushrod hole)
(Baer used to supply these with their braking systems years ago)
1" bore manual brake: CARDONE SELECT 131371
(1968 - 1976 C3 Corvette - deep MC pushrod hole)
Once you prove out what MC bore size you may like best, THEN spend the money on a "bling" MC if desired.
Oh, and the general rule with GM MC's is the 1/2" port is for the front brakes, and the 9/16" port is for the rear brakes (mentioning this because some MC's are reversed from others as far as which port is which). There are some exceptions...
There IS a difference - Thank you for choosing Hydratech!
Paul M. Clark <-- the Ukrainian - Slava Ukraini !
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
Old 10-08-2017, 01:50 PM
If I keep the push rod in the manual position vice pwr on the stock pedal it will just make the brakes very sensitive correct? So 5.7:1 vice 3.5/4:1?
Old 10-09-2017, 09:15 PM
Hydratech®'s Avatar
Exclamation Pedal rod angularity warning
Note that the brake pedal rod MUST enter the master cylinder dead on straight in a manual brake scenario. Discussions of drilling different holes in the brake pedal in efforts to alter brake pedal ratios are not valid because the brake pedal rod will then enter the backside of the MC at an inappropriate angle causing linkage bind, MC failure from extreme side loading of the pistons, and even possible complete failure of the brake pedal rod linkage entirely.
Summary? You MUST keep your brake rod connection in the factory manual brake top hole - no if's, and's, or but's about it.
Old 10-09-2017, 09:44 PM
Funny.... when you buy a 1969 Camaro Brake pedal assembly - it has two holes from the factory -- Manual -- and Power....
It's only about a 1 inch difference and the angle of the pushrod is hardly an issue. The pushrod swings thru an arc regardless - it doesn't go straight in and out. The pedal pivots thru an arc....
The difference between a power booster and a manual is taken up in the ANGLE of the mounting at the other side of the firewall.... the power booster is usually tilted back (at the top) slightly due to the LOWER hole in the brake pedal being used (less ratio).... and the manual is usually mounted flat - and uses the "upper" hole (more pedal ratio).
