Old 03-11-2020, 11:36 PM
Rodknock's Avatar
Rodknock Rodknock is offline
Default Ride Tech fuel filler/cap thingy continued
OK, continuing on with the fuel stuff. My Eyecrometer says it good
Notched the top to fit where the trunk lock is at, and trimmed it down a little. I figured I would keep it on the larger side, to help with possible flexing. Shouldn't hurt anything.
Welded in place. I got rid of the straight Argon gas I had in my mig welder, and picked up some 75/25 CO2 argon mix. Now the welder (not me, the machine), works like it's supposed to.
John Rodko
69 Camaro RS/SS
Rolling shell, minimal rust.
Heidts Pro G IRS/ Heidts Pro G Front
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
https://www.facebook.com/Angry-Johnn...?ref=bookmarks
The Following 5 Users Say Thank You to Rodknock For This Useful Post:
Goosesdad (03-12-2020), Roscoe03 (03-12-2020), syborg tt (12-08-2024), waynieZ (03-12-2020), WILWAXU (04-13-2020)
  #62
Old 03-18-2020, 11:05 PM
Rodknock's Avatar
Default Seam Sealer
Been busy lately. I did a little seam sealer tonight, but that was it. In case anyone doesn't know, using masking tape before laying it down, helps keep it neat, and makes clean up a lot easier.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
The Following User Says Thank You to Rodknock For This Useful Post:
  #63
Old 03-19-2020, 09:36 AM
slimjim's Avatar
slimjim slimjim is offline
What primer stage are you up to? I also need to seam seal similar locations and I'm currently in poly primer, I've just been trying to decide the best time to do it. I think I'll apply after epoxy sealer but before base coat but it may not matter.
NC
streamline 68 camaro
Build Thread here
Old 03-19-2020, 10:25 AM
Rodknock's Avatar
Jim, I'm only on my second stage of primer, but haven't done the areas shown, where the sealer is. It's just some overspray from doing the quarter panels.
The seam sealer is paintable, so I think you can actually go over bare metal, then just prime over it.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
Old 03-21-2020, 10:38 AM
Jimbo1367 Jimbo1367 is offline
Great job. I really like where this is going !!!
The Following 2 Users Say Thank You to Jimbo1367 For This Useful Post:
gmc427 (03-23-2020), Rodknock (04-13-2020)
  #66
Old 04-13-2020, 07:43 PM
Rodknock's Avatar
Default Slacker
Man, I've been slacking on posting here. It was buried on the second page..lol
So, anyway, I'm finished with the second round of block sanding on the body. Still a little more fine tuning on the tail panel/valance, then I'll move up to the firewall, which should be pretty straightforward since it's flat and doesn't have all the contours the tail panel has.
Here's the primer still wet, so you can see it's getting straighter.
Close up of orange peel. It's just primer.
Primer all dry. Had to leave for work, so it will continue later. At least it will have time to dry.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
Roscoe03 (04-14-2020)
  #67
Old 04-13-2020, 07:45 PM
Rodknock's Avatar
Thanks Jimbo!!!
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
Old 05-29-2020, 08:00 PM
Rodknock's Avatar
Default Re do of the seam sealer
I wasn't happy with the seam sealer. The primer ended up cracking on me, and as it turns out, paint prep melts it
We'll see how it turns out, when I prime it this time. As info, it was Eastwood seam sealer and there paint prep. I guess they're not compatible with each other.. Hmm
This side wasn't too bad, just had to do a small area
Redid this whole section here
Had to re-do both sides of this panel.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
  #69
Old 05-29-2020, 08:04 PM
Rodknock's Avatar
Default Final Blocking of rear quarters
Finally finished blocking the body shell. Did some 320 wet, so I could see how it looked. Seems straight enough to live with it.
Even though it's just grey primer, being wet really shows the light reflection.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
  #70
Old 05-29-2020, 08:30 PM
Rodknock's Avatar
Default Mixing the tinted sealer
I started mixing the tinted sealer the other day, just to see how it looked.
9 parts KD 3003 yellow to 1 part KD 3005 blue, to create a green, that's pretty close to what the color of the car will be.
These are cards listing some of the color capabilities using the HOK KD 3000 series primer/surfacers. Obviously the choices are limitless. You can actually spray your colors over this chart to see what your effect will look like.
I circled the one I'm using.
Close as it gets
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
The Following 2 Users Say Thank You to Rodknock For This Useful Post:
Goosesdad (05-29-2020), syborg tt (12-08-2024)
